Wont weld the joint - SOLVED
Hey,
I'm using an arc welder to weld to pieces of steel together but the weld bead just sits either side of the join and the join fills up with slag. I'm new to welding so i suspect i'm doing something wrong. THe pieces have been in an L shape should they be in a V shape? i tried 80 amps but it just blew a hole. there is at most a 1mm (less than 1/16) gap is that too much? I've ground everything back to bare metal with an angle grinder. I did do a short course in welding but it hasnt helped me very much, it was a little too basic.
material is 30mmx30mmx1.6mm (1'1/4 x 1'1/4 RHS 1/16) thick
settings are about 60amps
rods are E4113/ E6013 - according to the box they can weld in all positions.
Thanks for your help
