Old 06-29-2010, 04:48 PM
Take a look at what we have been working on
A picture says a thousand words:
www.2020ssi.com
bend-tech support forum:
http://www.2020softwaresolutions.com/cmps_index.php
Old 06-29-2010, 04:51 PM
Maybe if I window back a little you will get a better idea:
www.2020ssi.com
Old 06-29-2010, 05:05 PM
IceFyre13th's Avatar
IceFyre13th IceFyre13th is offline
putt putt golf course?
Old 06-29-2010, 05:22 PM
traxman25's Avatar
Um I likey!!!
And I know what it is. Muhahahaha
http://4xinnovations.com
Where class and quality meet price.
Old 06-29-2010, 05:29 PM
shaggy10000's Avatar
Kind of like a simplified cad. Soooo can i make drawings for a cnc plasma table with it? I notice the SE can it be added to pro as well?
Old 06-29-2010, 05:34 PM
Rock4XFab's Avatar
Give me give me give me give me OOOPs Please may I have one
Got to tell you chris I am man enough to tell YOU I think i need to go clean myself...
http://rock4xfabrication.com
1-847-672-9653
1-847-544-1823
Old 06-29-2010, 05:35 PM
Black Pearl's Avatar
Black Pearl Black Pearl is offline
Looks like Part66 generated with release 5 of Bend Tech SE. Beyond that I'm clueless
Old 06-29-2010, 07:18 PM
cummins6speed's Avatar
cummins6speed cummins6speed is offline
You have my interest
Old 06-29-2010, 08:15 PM
ferociousllama's Avatar
ferociousllama ferociousllama is offline
I would like to express my intent to acquire the pictured product....How long before this is made available?
Old 06-29-2010, 09:49 PM
4play's Avatar
4play 4play is offline
Ok, ever since I found this site ive been tossing around the idea of buying your software. Now that you've gone and done this I'll have to. Goodbye over complicated auto cad hello bend tech. well not right now but in the near future. Looks good to me
Old 06-29-2010, 10:28 PM
justin'sbig7's Avatar
justin'sbig7 justin'sbig7 is offline
that is hawt!
Old 06-29-2010, 10:53 PM
raceplayhavefun's Avatar
raceplayhavefun raceplayhavefun is offline
CAn we export it as a dxf?
Old 06-29-2010, 11:18 PM
scootek's Avatar
scootek scootek is offline
I am glad to see this day.
Keep burnin that $hit at both ends, cause its looking great!
Old 06-30-2010, 12:53 AM
Soooooo. Am i right?
Old 06-30-2010, 12:56 AM
Rock4XFab's Avatar
yes a simple sheet metals lay out software
1-847-672-9653
1-847-544-1823
Old 06-30-2010, 09:42 AM
Answers to a few of the questions:
We are working on a plate and sheet metal product that will tie into our tubing assembly. Bend-Tech Plate is aimed at the home hobbyist and the small shop. The general concept is to provide a product that will take less than a couple of hours to learn and just a few hours to master.
BT-Plate includes a very easy-to-use 2d CAD package with surprising power. It has all of the general 2d CAD functions including; points, lines, arcs, dimensioning, text, title block and holes. Of course you can create any hole shape you would like, including hole shapes of round, square, rectangle, slots and ellipse. You will be able to create all of your plate parts, use it to help figure out numbers for tubing and draw out the deck for the back of your house.
BT-Plate will also allow the design of bent sheet metal parts. Instead of working in full 3d you will be working on each flange at a time. Design your base plate, select an edge to place a flange and then fill in the blanks for bend angle, direction, radius and bend deduction. The software will then allow you to work on the new flange using all of the powerful BT-Plate cad tools. In the upper corner you will see your "bent" 3d part as you are working on the 2d surface. Push one button and the software will give you the flat layout with bend deductions implied.
Now as if all that wasn't enough, you will be able to bring your parts into the assembly module of Bend-Tech and combine your parts together and with the tubing in your projects.
We are targeting this fall.
It will export dxf files.
The module will be available for PRO as well as SE.
Cost: we don't have a price nailed down at this time. We will be very fair with long time customers, recent customers and new customers. Because the target of this is a separate module, there will be no or very little advantage to a customer purchasing Bend-Tech after the release date versus today.
www.2020ssi.com
Old 06-30-2010, 10:16 AM
www.2020ssi.com
Old 06-30-2010, 10:34 AM
Fabricator Innovator
Awesome new product Cris. Once you're done with a bent up part, can the software generate a flattened pattern? Can you do multiple plates in an assembly to do things like diff covers and whatnot? Will it calculate the weight of the finished product? Mirroring of parts?
This could be very handy. It wont be the only product out there for this type of CAD, but if the past is any indication, it will be the best supported and most reasonable value to be had.
Clinton
Tube Bandit Digital Readout for Benders
Past Builds: CNC TUBE BENDER - 4RUNNER
Old 06-30-2010, 10:47 AM
Once you're done with a bent up part, can the software generate a flattened pattern? YES
Can you do multiple plates in an assembly to do things like diff covers and whatnot? YES
Will it calculate the weight of the finished product? YES
Mirroring of parts? YES
This could be very handy. It wont be the only product out there for this type of CAD, but if the past is any indication, it will be the best supported and most reasonable value to be had. I think that we will be the only product at our price point. I KNOW we will be the easiest to use.
www.2020ssi.com
Old 06-30-2010, 10:48 AM
www.2020ssi.com
