Go Back OFN Forums > Shop and Tool Talk > Software Tech/Questions
Software Tech/Questions Do you use CAD? Curious about it? It can be a great tool to have in the shop. This is the place to talk about it!
Old 12-17-2007, 06:53 PM
rokspydr's Avatar
rokspydr rokspydr is offline
pro 105hd
1.5" x5" x 240*
5.125 clr
5.53 calibrated
Old 12-20-2007, 01:19 PM
bozowise's Avatar
bozowise bozowise is offline
Pro Tools 105
1.75" 120 wall DOM
6" 240*
CLR = 6.252
CAL CLR = 6.99
Bend Location Offset using front of die = -.625
Spring back seems to be right at 4.5*
How do these look?
Old 12-30-2007, 02:11 AM
Sites's Avatar
Sites Sites is offline
JD2 Model 4 bender:
1.75" x 5.5 die
CLR: 5.731
Cal CLR: 6.4075
Loc Offset: +1.894 (lining up with the end of the die)
Does this sound right?
Old 12-31-2007, 05:23 PM
Looks good
Old 01-29-2008, 11:29 PM
smackdaddy's Avatar
old thread new question
Originally Posted by rokspydr View Post
pro 105hd
1.5" x5" x 240*
5.125 clr
5.53 calibrated
jd- model 2 bender with 1.5" die 4.5clr and I am coming up with these numbers-cal clr=5.83,clr=4.69,offset=-.075 can eaybody verify these numbers or am I way off? Thanks
Old 01-30-2008, 10:04 AM
offset is a little small. The offset is the distance from (in your case) the edge of the die to the start of the bend. Usually closer to -.5
Old 03-11-2008, 07:20 PM
Mopars 4 Life's Avatar
alright..
Pro Tools HMP 200 vertical bender
6.0 x 1.75 die
CLR=6.252
Calibrated CLR=6.99
Offset= -.498
Thanks,Brian
Old 03-11-2008, 07:28 PM
Originally Posted by Mopars 4 Life View Post
alright..
6.0 x 1.75 die
CLR=6.252
Calibrated CLR=6.99
Offset= -.498
Thanks,Brian
Looks good!!!!
Old 05-10-2008, 06:04 PM
QuickSand's Avatar
QuickSand QuickSand is offline
JD2 Model 4 Bender
1.5" x 4.5" die
1.5" x .120" 4130 tubing
CLR = 4.689
Calibrated CLR = 4.80563
Bend Location Offset = 1.007
7 degrees Lead In Angle
8 degrees Springback @ 90 degree bend
A couple of questions:
1) Why is CLR = dieSize * 1.042 instead of just the die size?
2) My calculated Bend Location Offset is 1.007" but if I measure from my alignment mark to where I see the die bending the tube I get 1.125". Why the 1/8" difference?
Old 12-29-2008, 07:02 PM
RedRhino's Avatar
RedRhino RedRhino is offline
How do these numbers look?
Pro Tools 105
1.75" .095
6" 240*
CLR = 6.252
CAL CLR = 6.99
Bend Location Offset using front of die where the stap goes = -.625
Old 12-29-2008, 07:21 PM
Pro Tools 105
1.75" .095
6" 240*
CLR = 6.252
CAL CLR = 6.99
PERFECT!!!!
Old 01-02-2009, 01:45 AM
TennesseeRXP's Avatar
TennesseeRXP TennesseeRXP is offline
Im brand new at this but thought that the calibrated clr would always be larger than your clr. What gives with the 1.5" die? What causes it to be the only one smaller?
Originally Posted by TitanFab View Post
JD2 1" x 3" die
clr 3.03125
cal 3.5
B.O. .8125
JD2 1.25" x 4.5" die
clr 4.5625
cal 4.9375
B.O. .6875
JD2 1.5" x 5.5 die
clr 5.66
cal 5.625
B.O. .9375
JD2 1.75 x 5.5 die
clr 5.875
cal 6
B.O. 1.625 (had this die and strap for 9 years, The strap is a tad on the long side. Need to make another one o little shorter)
JD2 2" x 6.5 die
clr 6.75
cal 7.5725
B.O. .5
1" x 3.5" Square die
clr 3.791
cal 3.647
B.O. .375
Old 01-05-2009, 12:36 AM
dustybadlands's Avatar
dustybadlands dustybadlands is offline
Just finished my new stand, now I'm ready for some "calibrated" bends. In your "guide" (rev. Nov.,'06), is there something I'm missing or can you combine steps 2 & 4? I'm doing 2 sets of dies tomorrow and don't wanna waste tube. Triple "S" (Sorry So Stupid). Thanx in advance Cris.
Old 01-05-2009, 10:09 AM
You can combine them.
Old 01-05-2009, 08:54 PM
O.K. I got one done and wasted tube anyway(went slightly past 90). Here's what I got:
1 1/2" X 4.5 , 240
CLR= 4.5 (10.5-1.5)/2
Cal CLR=5.233
Offset using screw= -3.625
Now for the 1 3/4....
Old 01-05-2009, 08:55 PM
1 1/2" X 4.5 , 240
Cal CLR=5.233
Looks good
Old 01-05-2009, 11:47 PM
Dang Cris! You respond fast! I was hopin' to get back on and just edit my last post. O.K. here's the last one...
1 3/4" X 6:
CLR= 6.125
Cal CLR=6.408
Offset @ screw= -3.125
Old 01-05-2009, 11:52 PM
1 3/4" X 6:
CLR= 6.125
Cal CLR=6.408
Let 'r buck. Looks good.
Old 02-20-2009, 09:00 PM
curleysracecars's Avatar
curleysracecars curleysracecars is offline
1 5/8" x 6" PT Die Set
CLR = 6.252"
Calibrated CLR = 7.135"
On the bend offset...Ive always just lined the mark up with the edge of the die set, and have never had any problems. Is this okay, or do I need to find where the bend actually starts when the line is at the edge of the die?
Thanks Cris!
Kyle
Old 02-20-2009, 09:09 PM
Rock4XFab's Avatar
CLR = 6.252"
Thanks Cris!
Kyle
If you want things to be dead nuts you realy need to know where the bend starts on the die. My 6" radius die starts right at the edge so thats where I use. My 5" radius starts .375 into the die.
http://rock4xfabrication.com
1-847-672-9653
1-847-544-1823
