| Hotrod Fabrication Hotrod Fabrication |
09-07-2009, 08:44 PM
1963 Bel Air WAGON build
I havn't been on here in a while, been a little busy (had 2 boys). I recently realised that we are goinig to need more room to cart the chitlins around and they will have freinds that will want to go. Solution was a 9 passanger station wagon (my wife REFUSES to drive a mini van). So what I ended up with, after 7 months of searching, was a 1963 Bel Air Wagon with no motor, tranie, rear end, radiator, or drive shaft. Not a big deal except for the rear end cause as i have learned over the past 3 weeks is that they are hard to find here in SW Washington. I did yesterday, come accross a ford 9 inch that is the right width (60") and it had disk brakes (bonus). Couldn't pass it up. The problem is that nothing lines up (both are controll arm/ coil rearends but completly diffrend as expected) I am thinking that my best bet is to cut everything off the 9 inch and start with a clean canvas. Anybody do this on this site? Have advice? Links? It will be pretty easy to do just want to be better prepared before i do it, after all this isn't a trail rig that don't really matter as long as it flexes, this will be a on road rig that will see freeway miles. Any advice is appriciated
Thanks much
here is a pic as she sits;
09-07-2009, 10:42 PM
I'm so wanting to do a wagon, but just don't have the $ or havn't come across the right "take it outta my field" el cheepo..
I've got a 468ci BBC driveline that's pretty badassed, and I want to tub/bag one and leave it semi ratty so I can have an obnoxious car to take my (now 3yo) son to little league games etc
Good luck with yours man, it looks like a nice place to start
09-07-2009, 10:45 PM
Pull out the Plumb bob and taper measure. Drop the new rear under it and square it up. Them move mounts accordinly to match the frame side..
http://rock4xfabrication.com
1-847-672-9653
1-847-544-1823
09-07-2009, 11:10 PM
Thanks, i know what you mean about finding one for less than 4k, i actuall pulled this out of a feild lol, i plan on leavin it ratty for a while thats whats badass bout old stuff, no matter what stage of the build it is still cool, rusty=cool primered=cool finished=cool ect...
09-07-2009, 11:11 PM
I am just worried about it being off centered or not squared up, but ill give it my all, thinking about trying to find some pre fabed tabs im thinking.
09-08-2009, 01:49 AM
picked up a muncie 4 speed
and a box of parts and a block painted super green, (that will be painted)
http://i540.photobucket.com/albums/g...wagonparts.jpg
I was told the motor was fresh but i am going to go threw it any way, its a 4 bolt main 350 came with just about everything. Than its back to the rearend
09-08-2009, 08:36 AM
Thanks for the links, except the hubgarage one didn't work. I might lookinto the kit from currie or maybe just try to wing it. I am trying to find some stock controll arms to start with as a template for my tube controll arms but havn't had any luck as of yet.
09-08-2009, 08:16 PM
here is the 9 inch i am going to starts hacking away on it today to get it bracket free
09-08-2009, 08:29 PM
Sorry try this one.
http://www.cardomain.com/ride/3336991
Are you going to make your own front and rear control arms?
09-08-2009, 10:18 PM
Frount and rear? i plan on making the ones for the rear i was thinking a bout 2 inch DOM not sure on wall yet. Also gonna need some ends, any recomendations?
here is the 9 inch striped
09-09-2009, 11:26 PM
I think i will build the bottom controll arms since that will be easy except for the spring bucket, wich i am hoping to find some stock controll arms to use as a template but havn't had any luck as of yet. The pan hard bar is intact so i might just put new bushings in it and leave it.
09-11-2009, 04:27 PM
I believe that originally that car had the springs mounted on a bracket welded to the axle tube. You might be able to find a pre-made coil bracket/bucket from either of these guys that would work.
http://www.ballisticfabrication.com
http://www.ruffstuffspecialties.com
You might also check with Art Morrison too, they might have one as well. Plus they aren't that far from you.
http://www.artmorrison.com
09-11-2009, 06:56 PM
Thanks i am trying to get some messurments off a stock controll arm to start with or have one on hand as a template because the spring bucket is on the controll arm it makes the messurments more critical
09-11-2009, 11:51 PM
Motor is all ready to drop in, once i get the rear done,
Didn't want anything fanch, just a plain jane 350 4 bolt, bored .30 over, mild RV cam, 164 heads mild port (202's are a comin'), RPM intake mild port, 600 CFM Edlbrock carb, hooker headers, HEI,
09-11-2009, 11:56 PM
getting ready to start on the trailing arms and mounts, where is the cheepest place to get polly bushings and sleves, i bought some a while back for like 8 bucks a set but can't rember where.
09-13-2009, 02:04 PM
lower front control arm bushings from a xj cherokee are $7-8 at advance or vato-zone.
09-14-2009, 01:24 AM
Is that 9" from a Lincoln Versailles?
09-14-2009, 09:17 PM
I am pretty sure it is
Powered by vBulletin® Version 3.8.0 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
