Old 08-31-2009, 05:58 PM
Frijolero's Avatar
Frijolero Frijolero is offline
Band saw Conversion?
Whats up everyone?
Im new here and cant wait to start sharing pictures of things I build and learning some new stuff... Running out of time before I have to go back to getting my but kicked by textbooks in college though.
I just, and when I say just I mean less then two hours ago, bought a woodcutting bandsaw from my neighbor for 80 bucks and its in great shape so I figured for the deal and for the fun I'd turn some new pulleys for it and slow it down enough to cut some plate and Im happy
So my question is:
Has anyone ever modified a wood cuting band saw to be able to cut steel with it?
Please keep in mind that Im a college kid working on a budget so don't go telling me to get rid of it and get a real saw because this is all I can afford.
here is "BS" in question:
http://www.cncsave.com/listings/33696.htm
Thanks
Danny
Old 08-31-2009, 06:06 PM
FrogDog's Avatar
FrogDog FrogDog is offline
Hey Danny, there was a few threads here on that...
http://www.offroadfabnet.com/forums/...ead.php?t=4404
never done it myself, but all i can do to help atm....
Cheer'z Bro
Dog.....
'Dog' is Never Wrong, Only Mistakin'
FrogDog FabWorx
Old 08-31-2009, 09:00 PM
SlightlyModified's Avatar
SlightlyModified SlightlyModified is offline
Just done it with a 14" wood saw. Just figure out your motor rpm, blade puley diameter, and do the math to figure your motor pulleys. My saw was something like 1725 rpm, 14" blade pulley, I used a 1" or maybe it was 1 1/4" motor pulley and a 12" pullley on the shaft connecting the blade. This put me at a free running speed of about 900FPM if I remember correctly.
Old 08-31-2009, 10:37 PM
Frijolero's Avatar
cool!
did you buy your pulleys or make them?
Old 08-31-2009, 10:45 PM
miteclgst's Avatar
miteclgst miteclgst is offline
Mcmaster Carr (mcmaster.com) different size pulleys and any kind of shaft you need. they also have step pulleys if you would like the ability to vary the speed for different materials
Old 08-31-2009, 10:55 PM
Frijolero's Avatar
Duh! I didnt even consider ordering... All that was in my head was...Search and search at the hardware store or try to make my own
THANKS!
Old 09-01-2009, 12:41 AM
Frijolero's Avatar
What kind of material have you been cutting since you changed the pulleys?
My new saw also has a motor speed of 1725 rpm and 14" blade pulleys but isnt 900fpm too fast for steel? I thought you cut aluminum at around 1000fpm on a bandsaw and steel was less than half that...?
Old 09-01-2009, 01:35 AM
900 Will work with a good quality blade, for Aluminum.
However for any steel you need to be down in the 80 to 200 range
Old 09-01-2009, 12:27 PM
Sorry Actually my numbers came out to 650fpm for my saw. For me to get down to 200, I cannot do it with just two pulleys. With my 1.25 motor pulley, I would need the other pulley to be 39.5" diameter, ha........
Give me your specs and I can figure it for you, if you don't want to do the math. Actually, give me your e-mail and I'll just send you an excel spreadsheet that you can just plug your numbers into.....
Old 09-02-2009, 05:42 PM
Frijolero's Avatar
I dont mind doing the math...I had just not measured anything.... or for that matter read well, The motor turns 1720 rpm
Its got a cone step pulley on the motor and the smallest has an OD of 1.125" while the input pulley that drives the saw measures 5.5".
So theres a gear reduction of 4.8 to 1 between the motor and drive pulley. With 14" OD Blade pulleys that puts the FPM at 1313.
So im putting together a pillow block with the 5.5" pulley on one side and a 1.5" pulley on the other, then I'll run a belt from the 1.5" to a new 12" on the input to the saw.
So from
1.125" to 5.5"
with the 5.5" running a 1.5"
and the 1.5" turning a 12"
and the 12" turning the 14" blade pulley
= 161 FPM
Old 09-02-2009, 10:06 PM
161 FPM
Be sure that you get a good blade because you're on the high side.
Also use actual Cutting oil, just a little.
Old 09-02-2009, 11:14 PM
Frijolero's Avatar
Well I got it as low as I could go with what I found at my local hardware store:
10" pulley and a 1" pulley
So....
Used bandsaw - $80
Pulleys and Pillow Block - $66
auto belt from kragen $10
Total: $160 ,with the gas spent
Recalculated the speed and its actually 131 SFM
I think I may go back later and replace the garage opener hanger looking stuff for some rectangular tubing but right now there is no flex or swaying when its running
Thanks for the help guys!
Im going to cut and weld some blades at my HS and stop by the hardware store to pick up some cutting fluid.
Old 09-03-2009, 01:21 AM
FrogDog's Avatar
That is awesome. Converting something is always kewl .. '' .. Other than cut speeds.. What did you decide on blade pitch, width, length and thickness .. And will the mechanical operation such as Idler pullies, bearings, tention and throat be an issue for size, longevity, true cut..
I guess time will tell...
I look at it this way .. It's simler to moding my jeep.. Do 1 thing, and 10 usually comes after... hehe...
Cheer'z Bro.. good luck, well done....
Dog.....
P.S. .. I do believe the multi purpose angle may cause some grief...
FrogDog FabWorx
Old 09-03-2009, 01:56 AM
Frijolero's Avatar
For blade...I'll just go with whatever my H.S. shop has in hand by way of rolls and weld a couple different blades together and just see what works best for the speed. As far as the mechanical components, I would imagine they would have less wear since they are all receiving 1/10 of the wear as far as turning goes..if I break something I'll just upgrade down the line
I know that the slotted angle was not the best idea but its just what I had on hand
Old 09-03-2009, 02:41 AM
FrogDog's Avatar
Ahhh,, the H.S. fringe benifit thing... hehe.. never thought of that ... .. sorry
Dog....
FrogDog FabWorx
Old 09-03-2009, 08:58 AM
Flatline's Up!'s Avatar
Flatline's Up! Flatline's Up! is offline
Nice work man... IMHO if the slotted angle works, why change it? it looks racer cool w/all the "race holes" in it
Old 09-03-2009, 12:57 PM
Frijolero's Avatar
Dog....
haha..yup high school fringe benefits...Sometimes Im there everyday of the week when Im building stuff, using the band saw and mill alot, thats why I got the bandsaw to have at home and looking for a drill press too.
I know, if only I had some 1/2" dimple dies
Old 09-03-2009, 11:01 PM
paranoid56's Avatar
paranoid56 paranoid56 is offline
how does it work? go back to your school and make some dimple dies on teh lathe. i think the smallest dimple i have is 1" or .75. cant remember
Old 09-03-2009, 11:42 PM
Frijolero's Avatar
I'll tell you guys how it works tomorrow after I get some blades... all I have cut is some aluminum with a wood blade on there and it felt pretty smooth.
Are there cad files for dimple dies online anywhere? I have used them very little some I am really not familiar enough with them to design my own.
Danny
Old 09-04-2009, 02:42 AM
paranoid56's Avatar
i have the DWG file for a 1" whats your email
