Old 07-16-2009, 08:33 PM
RyK's Avatar
RyK RyK is offline
jeep TJ tube door
20 feet 1.5 tube 45$ + 40$ latch
to be continued
Old 07-16-2009, 08:43 PM
shaggy10000's Avatar
Stick welder ewwwwwwwww. You definitely use one better than i do
I like the look. Wher'd you get the latch?
Old 07-16-2009, 08:49 PM
RyK's Avatar
RyK RyK is offline
"Small Bear Claw Latch" try on ebay
i use very cheap 110v welder mig with no gas
Old 07-16-2009, 09:43 PM
curleysracecars's Avatar
curleysracecars curleysracecars is offline
Nice job! Where did you source the latches if you dont mind me asking? Im looking for a pair of latches for a tube door project of my own. Ive seen them in the street rodding industry for around $25-30 per pair. Is this a decent price? Where did you get the red knobbed handle deal?
Again, nice work!
Kyle
Old 07-16-2009, 10:19 PM
RyK's Avatar
RyK RyK is offline
Again, nice work!
Kyle
for latch "Small Bear Claw Latch" on ebay
"red knobbed" is tractor red hitch pin on tractor part store
Old 07-17-2009, 09:26 AM
Ladderbar's Avatar
Nice another project to add to my list......lol.
Old 07-17-2009, 11:39 AM
SUPERD's Avatar
SUPERD SUPERD is offline
very nice, looks like that wasn't the first pair you have made.
I have been eyeing the bear claw latches for a while, do they fit the striker well or is that what the piece of bungie is for? "anti-rattle device"
Bend tec or just wing it?
I am in the process of drawing some up for myself but now I think I need to change a few things, I like your style better.
I was gonna do the single piece loop like OR-FAB's but yours just fit the lines of the tub so much better.
Tractor supply usually saves the day for odd hardware!
Old 07-17-2009, 12:39 PM
RyK's Avatar
RyK RyK is offline
yes is my first door i have made
i'm newbie on fabrication!
Old 07-17-2009, 12:52 PM
SUPERD's Avatar
you got the gift, keep it up.
what about the bungie?
Old 07-19-2009, 09:35 PM
RyK's Avatar
RyK RyK is offline
bungie is anti rattle bump stop :)
Old 07-23-2009, 07:45 PM
RyK's Avatar
RyK RyK is offline
Old 07-23-2009, 08:04 PM
Ladderbar's Avatar
Now that's nice. Good job.
Old 07-23-2009, 10:09 PM
Man, those really came out nice. The flat black and diamond plate is my kind of style.
Old 07-31-2009, 02:38 PM
TRIGGER's Avatar
TRIGGER TRIGGER is offline
Hellraiser
Man,,, very, very nice. Those doors look pretty good and the latch work loops pretty pro. Nice Jeep as well.
Now I'm gonna have to build some.
______________________
2008 F-250 FX4 PSD
1997 F-150, 1998 Wrangler
1971 Bronco, 1975 F-150, 1977 F-250
Old 08-05-2009, 07:23 PM
traxman25's Avatar
Very nice, I like them!
Are the stock striker plates in the Jeep 5/16 which is causing your rattle issue? Or is it just the quality of the latch?
http://4xinnovations.com
Toyota tubing.
Old 08-14-2009, 10:52 PM
RyK's Avatar
RyK RyK is offline
finish!!!
Old 08-15-2009, 12:27 AM
pertneer's Avatar
pertneer pertneer is offline
Nice, I like the contrast with the diamond plate being black.
Old 08-15-2009, 02:13 AM
Hollywood's Avatar
Hollywood Hollywood is offline
Looks Great. Good DIY.
On your next set, which Im sure someone will want you to make some, Look into sleeving the hinge end with 1.25 tubing with a 45deg. cut or straight hole saw Notch on the Outer 1.5 tubing. This way you will have a better contact to the hing pin and stronger hold. You just have to make sure you have a clean weld around the sleeve connection or else it won't look to clean after all.
Good Job, Clean Jeep.
Old 09-02-2009, 11:16 AM
LuckyCharm4x4's Avatar
LuckyCharm4x4 LuckyCharm4x4 is offline
Hollywood, I am not sure what you are talking about, diagram?
Ryk, what did you use for the hinges?
~Bry
Old 09-02-2009, 11:58 AM
can you get a pic that's flush with the side of the Jeep so we can see how far they stick out please?
~Bry
