been making some headway these past few days...
managed to get the front parts of the cage welded up.. a couple of bits i`m not proud off but theyre the bits up against the roof so they`re out of sight. the weld itself is solid but it aint the prettyest....
decided to check clearance with my seats and doorbars....
TIGHT!!!! but they fit..
at the minute clearance for the roofbars is tight.. but i think i can drop the seats with some modded sidemounts...
the seat bars are 40mm tube so there must be another 50mm i can come down with the seat...
holesaw`d through the scuttle so i could link the cage to the turrets.. no dimensions were given with the cage kit so i scratched my head made a made mark and went for it...
also tried putting the roof bars in again but no matter how i position them i think my head will catch them ( will try again tommorrow mybe put them in a V insted of an X... if not i`ll have to miss them out)
also had some cutting and shaping for the A post supports (only supplied as a bare tube)
initially i cut it as 1 single run inside the door bars but unless i used a button for a steering wheel my hands would hit it... going to the doorbar and then down pulls it over about 3 or 4 inchs and should give enough knuckle clearance...
