Old 03-08-2009, 04:53 AM
ldanny's Avatar
ldanny ldanny is offline
Hossfeld bender..
i have been looking into a bender, why is the hossfeld so much more? how is it compared to the standard bender like protools? the model 2, doesnt look like it uses dies like JD2 or 105 ..
thanks
Old 03-08-2009, 05:35 AM
try reading this link by keithXtream, excellent comparison write up
http://www.offroadfabnet.com/forums/...ead.php?t=1668
as far as the hossfeld goes. ive use one but not for bending tube.. it is known for tube bending for sure but is also designed for various types of metal bending forms that protools and JD dont.. probly the main difference there...
's Bro
Dog
Old 03-08-2009, 05:28 PM
ldanny's Avatar
thanks.. i found an used hossfeld and a 105 so i was debating between the two
Old 03-08-2009, 05:37 PM
The PT105 will only bend round tube, pipe and square tube, whereas the Hossfeld will bend that as well as flat bar,angle and channel both the easy way and the hard way. The Hossfeld is a quite old design, but it works well and can be used to form numerous shapes. I guess it boils down to what you want to do with the bender. If you're only going to be bending tube, then the PT 105 will do a good job for you. But if you want to be able to bend other shapes too, then the Hossfeld may be the way to go. Of course you'll have to buy the appropriate dies for each size no matter which one you go with.
Old 03-09-2009, 01:30 AM
shaggy10000's Avatar
Also think about if any of your friends have a bender. Makes it so you can share dies.
Old 03-09-2009, 03:06 AM
ldanny's Avatar
thanks for the advice. none of my close friends are into offroading so i cant really share. hossfeld didnt have prices for their dies, i wonder why
Old 03-09-2009, 03:31 AM
they have some prices on there starter kits, i'm sure you would have to contact them for more item detailed prices...
my only other comment on this issue would be exactly as captainfab said...
although i use JD2-3 with no complaints...
's Bro
Old 03-09-2009, 08:01 PM
ldanny's Avatar
thanks.. i waited too long on the hossfeld and the guy sold it. ($400 bux)
