Go Back OFN Forums > Marketplace > Vendor Marketplace > Rock4x Fabrication
Rock4x Fabrication (Business Vendor) Products available from Rock4x Fabrication
Old 03-16-2007, 01:36 AM
Rock4XFab's Avatar
Bumper Clevis mounts
Just knocked a few of these out...
Drill the hole, rosette the rear, face weld the front. It does not get any easier. Dont trust a single face welded bracket by competitors
Bumper rings are $19.99 pc
http://rock4xfabrication.com
1-847-672-9653
1-847-544-1823
Old 03-16-2007, 08:49 AM
RajinCajun's Avatar
RajinCajun RajinCajun is offline
Those look sweet.. Any pics of them installed?
Old 03-16-2007, 11:55 AM
balterbuilt's Avatar
geez, those are almost too fancy for my tastes :-P
Old 03-16-2007, 12:00 PM
Rock4XFab's Avatar
Ya well you know me I have a unique fashion sense ... Just trying to bring fashion and function to the table. LOL
1-847-672-9653
1-847-544-1823
Old 03-16-2007, 01:17 PM
$CEEP's Avatar
$CEEP $CEEP is offline
damn.. thems NICE. will definatley order som next time i'm in need.
what are the odds of getting one similar but not turned down at the end, so it could slip inside a piece of 1.75 x .120 wall for the buggy guys?
Old 03-16-2007, 02:22 PM
All you need now is to thread them for a weld-free install. Just drill a hole and tighten the nut.
They look good.
Old 03-16-2007, 05:26 PM
Those ARE nice! How long is the shank on them?
Old 03-16-2007, 05:30 PM
Apparently a little more than half the height of a soda can
Old 03-16-2007, 05:42 PM
Would that be full or empty?
Old 03-16-2007, 08:01 PM
nu_bronco's Avatar
nu_bronco nu_bronco is offline
Those look great. Looks like something that would be a good starter project for someone wanting to learn how to use a lathe and such. I want to make a pair. Good work.
Old 03-16-2007, 08:02 PM
KeithXtreme's Avatar
OFN Member
Man Scott, you should have told me you had those...you could have sent a box of those with all the gussets, my customers will eat those up....
Chopworx Motor Co.
Business# 918.607.3328
Chopworx.com
Old 03-16-2007, 10:20 PM
Rock4XFab's Avatar
I should have about 10 in a week.. We just did these real quick to get them into a bumper. I am swamped with one of my Vendors who has screwed up every order I have given him since last week. I got in this morning at 8am and just got off the phone with the last discruntled customer. I have talked to this vendor 8 times today, not once were they appolagetic. SOOO new out look with that product step up or out of the way, I now am looking into making another product line. Sorry for the vent. Keith the gussets I will box up tomorow... Give me a ring if you are around.
1-847-672-9653
1-847-544-1823
Old 03-16-2007, 10:37 PM
Rock4XFab's Avatar
Installed on one of our Bumpers
1-847-672-9653
1-847-544-1823
Old 04-16-2007, 06:40 PM
traxman25's Avatar
Scott,
Can you have these made to fit inside a 1.5" tube? so the O.D. on the shaft of 1.255 or so?
I know I've seen them before but can't seem to find them now that I'm thinking of using them...
http://4xinnovations.com
Toyota tubing.
Old 04-17-2007, 05:04 PM
Rock4XFab's Avatar
Originally Posted by traxman25 View Post
Scott,
We probably could But I would not want to for liability... If you insert into a tube. A straight pull would not be an issue, BUT if someone pulled off to the side I would be affraid the tube would fail.. Hope that made sence.
1-847-672-9653
1-847-544-1823
Old 04-17-2007, 11:07 PM
traxman25's Avatar
Yeah it makes sense, if the bumper is poorly designed.
Toyota tubing.
Old 04-20-2007, 11:21 AM
if the tube was braced right at the edges of the end of th tube with and exposed "mouth" for the shackle holder to be inserted into i woudl think the strength would be sufficent.
Old 06-17-2007, 10:53 PM
Sarge's Avatar
Sarge Sarge is offline
What do think about using a thick piece of plate as a backer and making them so they would swivel 360*???
Just a thought...
Sarge
Old 06-18-2007, 01:07 AM
B-Rad's Avatar
B-Rad B-Rad is offline
Just a thought...
Sarge
Unless it was in a bearing, it would score the material and eventually fail during a pull. They make swiveling ones like you are talking about, they bolt on but are pretty expensive IIRC
Old 06-28-2007, 11:05 AM
Sarge's Avatar
Good point . I guess under most circumstances it wouldn't matter if they swiveled , proper usage of a strap would take care of that anyway .
Got any made yet , Scott? lol...
Sarge
