Old 02-17-2007, 07:05 PM
Jeonlyep's Avatar
Jeonlyep Jeonlyep is offline
Do I?
Do I take credit for these? Or say that Opie welded them?
Old 02-17-2007, 07:37 PM
phaxtris's Avatar
phaxtris phaxtris is offline
who is opie ?
looks like you need more voltage, but id say it looks alright
Old 02-17-2007, 07:48 PM
Jeonlyep's Avatar
Originally Posted by phaxtris View Post
who is opie ?
Opie from the Opie and Anthony show MX 202....
That's kinda what I was thinking. I cranked it up some more, but now the batteries are dead in the camera.
Old 02-17-2007, 11:25 PM
Jeonlyep's Avatar
Charged the batteries.
Definitely in deeper...
Old 02-18-2007, 04:52 AM
WolfMetalFab's Avatar
WolfMetalFab WolfMetalFab is offline
Now you seem to have bad undercutting on the weld, might be a touch too hot, to fast travel speed (doesnt look like it tho) or need to bump up the wire feed.
Also may have a improper torch angle to the work piece/joint
Old 02-18-2007, 12:15 PM
Jeonlyep's Avatar
Yea, I see what you're saying. I think I should have bumped the wire speed up a bit.
Thanks for the advise guys.
Old 02-19-2007, 12:51 AM
dgrant's Avatar
dgrant dgrant is offline
thats not really under cut its under fill. if the machine is set right then slow your travel speed
Old 02-19-2007, 01:00 AM
Jeonlyep's Avatar
I think that for that weld I had the wire speed too slow, but I'll watch my speed for the next group. Thanks
Old 03-04-2007, 05:56 PM
treebark's Avatar
treebark treebark is offline
weld appearence
The first weld shown has improper fusion, try cleaning the material well and pause longer at the edges of the weld pool. The second weld has underfill like someone said, if the depth of preperation is to deep for one pass try to clean the weld and put a cover pass on it. The way to tell if travel speed is to fast is the weld apperence has a "feathering" look. enjoy
