Old 11-30-2017, 05:50 PM
Extension Cable Plugs
I'm having a heck of a time finding a simple NEMA 6-50R connector in the same style as a typical 6-50P.
Find the surface mount all day, but I want to build this cable a little cleaner then just hanging a metal box on the end.
Oh, and I would like to price to be in the $10us bracket
Old 11-30-2017, 06:38 PM
I couldn't find one either so I just made mine with the stupid box hanging off the end. They exist though, for example:
Eastwood Item #20029
Old 11-30-2017, 08:20 PM
http://www.galco.com/buy/Arrow-Hart-...xoCER0QAvD_BwE
same...
https://www.amazon.com/dp/B00HJJ0YHO...bit_scomp_sav0
Maybe?
Old 12-01-2017, 01:13 PM
That would work nicely; but it is about 300x over priced!
Yes I know I just don't want it bad enough
Old 12-01-2017, 01:15 PM
Plugs
Maybe you could make your own out of woood!!!!
Old 12-01-2017, 04:20 PM
Freeg'n damn fine idea
Old 12-02-2017, 09:13 AM
Switch to twist lock. Mighty fine results.
Old 12-02-2017, 12:35 PM
Can't change the male end of the plug, it voids the warranty AND want to standardize the various boxes on the floor as much as possible...
Learned yesterday, the Red box will require its own circuit due to being rated over 40A and maxing over 80A.
It is always the details that cause you to step back and look at the whole picture.
Half the shop has one plug and all the new stuff has another
Old 12-02-2017, 02:33 PM
Remove the cord from inside the machine?
Old 12-02-2017, 10:25 PM
Bought a 6-50R Box for a tic less then $15, the other end for under $5 and $50+ for the 3/10 cable.
I'll put it together tomorrow and that will be that.
Should'ah made it out-ah wood
Old 12-03-2017, 01:27 AM
Are you doing 30amp max? I think 50amp calls for 6awg. My 220 circuit is 30amp and I run 3/10 also on my extension, but if i had a 50amp circuit I might bump it up.
Old 12-03-2017, 02:03 AM
Everything I plan on running with this cable is under 20A, & so, #10 gives me enough cushion.
Old 12-03-2017, 02:16 AM
cool same here for now! Sorry you didn't find an affordable female end.
