Old 05-31-2015, 10:02 PM
deranged's Avatar
deranged deranged is offline
Anyone up for another build?
Well, here goes build #2....
Specs...single seat, 1000cc motor, 900#. Anyone still on here?
Justin
Old 05-31-2015, 10:15 PM
let'er rip tatorchip
Old 05-31-2015, 11:29 PM
deranged's Avatar
Well, here we go.
Here is the lower rail section laid out on the flat acorn table to get things started.
And the front nose section tacked together.
Old 06-01-2015, 12:58 AM
Are you working with a kit, plans, or scratch?
Old 06-01-2015, 01:31 PM
I'll be watching!
Old 06-01-2015, 10:56 PM
deranged's Avatar
Well, allrighty then. Here we go.
I am building this from plans. It is a re designed piranha basically. The plans are from Krasch designs. He calls it the AR-51.
Here is where the rear a-arms, and the spool go. The front and rear plates, or bulkheads are water cut, pieces for some precision. There is a 4x2 tube on the bottom of this weldment that serves as support and for the spool adjustment front to back.
Here I am starting to fit things together. I have the pivot crush sleeves for spacers to keep things squared up.
Also the plate work is all keyed to lock things together.
Think I need more clamps??
Old 06-01-2015, 11:00 PM
deranged's Avatar
Here is my little fab table I built just for the build. I have the center line marked down the middle to keep things nice and straight. This is the bottom rail, and the rear section going together.
Old 06-02-2015, 08:09 AM
I like it! Is this going to be used at Silver Lake?
Old 06-02-2015, 03:05 PM
deranged's Avatar
More like abused. LOL
Justin
Old 06-03-2015, 10:47 PM
deranged's Avatar
Well, I made a table to build the chassis on. It has a center line down the middle to line everything up with.
As I made the lower, and mid rails, I put a center line on the all of the perpendicular to direction of travel tubes to keep things centered. And then I used a string line, and a square to ensure things are all on the center line.
Old 06-03-2015, 10:50 PM
deranged's Avatar
Well, after that, I didn't take any pictures until I had a full basic chassis..
Old 06-04-2015, 12:59 AM
Looks like Rick Krasch makes a kit/plans. Looking good!
Old 06-04-2015, 01:13 PM
RogueFab's Avatar
RogueFab RogueFab is offline
Pretty cool tiny build. I like it so far. What is the powerplant from? Streetbike? Snow machine?
Old 06-04-2015, 10:12 PM
deranged's Avatar
It is a Krasch design car. AR-51.
She will be powered by a GSXR 1000 sport bike motor. A sled motor would would be killer, but packaging the clutch would pose a challenge. You could stretch out the chassis to make it fit.
So, it really helps to have access to a water jet... Here is the rear sprocket, rear rotor, front rotors, shock mounts, and a couple random smaller parts.
Gotta keep it cool somehow!
MMMMMMM, MOAR parts!!! Calipers, master cylinders, 930 cv's braided lines, cv boots.
And the rear spool!
Old 06-04-2015, 11:30 PM
Question for you. I have thought about waterjet cutting brake rotors for various projects over the years but have never actually done it because I wasn't sure about the material choice. What do you cut your rotors from? Mild Steel, Stainless (what grade?), AR plate or...?
The chassis looks good so far. I wish I had the time to build something like this, it looks like a lot of fun.
Thanx,
Old 07-30-2015, 03:51 PM
deranged's Avatar
Whew, sorry for the late reply. I have been in Mexico for the last month on a project for work. As for the material, it is your typical A-36 steel. They were drops laying around at work. BUT, it just so happens that we put in a zinc/nickle plating line for a brake manufacturing company that is going to run my rotors through their line. That will completely get rid of the scale on the steel.
My last car, I used 304 stainless steel. I chucked them up in a lathe and put a cross hatch pattern in them, and they did well for what I did.
Justin
Thanx,
Old 07-30-2015, 04:37 PM
Very nice,love to have the time also,that's going to be wicked fun
Old 07-31-2015, 02:18 PM
TS3g's Avatar
TS3g TS3g is offline
Nice man! It looks like it's going to be a lot of fun!
Old 08-05-2015, 01:15 AM
johny5's Avatar
johny5 johny5 is offline
I like keep the pics coming
Old 08-05-2015, 03:13 AM
So your spool, does the brake rotor and sprocket bolt between the spool and the cv joints? I ask because I am in the process of designing a much smaller version of an offroad kart and while it's going to use a swing axle style irs and u-joints instead of cv joints I had thoughts of putting the drive sprocket and brake between the carrier bearings (for support) but if you're doing it the way I am thinking you are it would make the sprocket and brake easier to service. Packaging can be hard to figure out while designing something like this.
Thanx,
