Old 11-09-2006, 11:27 PM
B-Rad's Avatar
B-Rad B-Rad is offline
Make a believer out of me
Guy sent me this drawing to go in his GMC van........dont ask. Is this something I could plug into bend tech and figure out where my bends need to be? 1.5" tube, 6" CLR die
Name:	gmc van main hoop.jpg
Old 11-10-2006, 12:00 AM
The answer is yes. A couple of the numbers need to be back figured:
If this is something you want me to do to get you the right numbers, then I need you to find the CLR, Calibrated CLR and the Bend Location Offset from the following pdf file:
http://www.2020softwaresolutions.com...ation_0611.pdf
I think the part should be 4 bends (the print looks like maybe 5). Is this correct?
Please give me hard numbers. Not min and max numbers.
Old 11-10-2006, 12:07 AM
B-Rad's Avatar
Ill find out that stuff about my die this weekend and get back to you. I think I found a free computer so the software is the next buy
Old 11-10-2006, 12:17 AM
If you are using a Model 3 or a 105, read the above calibration doc and go to step 5 to make sure which way to put the tubing in. Line the Location marks in the following pic with the front edge of your die (not the strap or screw). I reduced the 69 to 68.5 and increased the 53 to 53.5 to meet the min/max issues.
The cut length is at the top of the screen.
You will find the mark locations under that.
The angles are the angles of bend after the tube is out of the bender (you account for your spring back).
I did an educated guess on your tooling calibration, however, I have been known to be getting pretty good at this.
I have no idea what the run of 5 and rise of 3 is for in your print in the upper right hand corner.
Old 11-10-2006, 12:21 AM
YEAH WHAT HE SAID!
Old 11-10-2006, 12:28 AM
Originally Posted by scootek
YEAH WHAT HE SAID!
You like that?
I used a CLR of 6.25, a Cal of 6.875 and an offset of -.75
cross my fingers and he should have a pretty good part. This is guess work because the calibration isn't done.
B-Rad's Avatar
the top right is different then the left. It has to clear the sliding door thingy.
I would *guess* that he meant 5" from the beginning of the bend to the outside of the down tube but it kinda looks like it has to clear a 5x3 box or something. Not the best drawing but better than some Ive gotten from people
Old 11-10-2006, 12:32 AM
There is no way they would know where the beginning of the bend would be. I think you need to get a better definition. At this point if the part doesn't fit because you don't understand their print, YOU are going to be the one to eat the part.
As sure as you get something I dare work off of, I am sure we can get something figured out.
Old 11-10-2006, 12:40 AM
You like that?
I enjoy your knowlege.
Old 11-10-2006, 12:46 AM
B-Rad's Avatar
Not making anything at this point. Dude is a weird guy, can tell just from the way he types. Just trying to get myself to pony up for the software.
Old 11-10-2006, 12:49 AM
Got ya. Wew, I was afraid I was going to need to sober up this evening and design a part.
Sheesh, I can give you about 125 reasons to pony up if you are interested.
Old 11-10-2006, 02:00 AM
B-Rad what the heck are you waiting for?
Old 11-10-2006, 02:01 AM
Rock4XFab's Avatar
Reason #126
This guy didnt have software to bend a cage....
http://rock4xfabrication.com
1-847-672-9653
1-847-544-1823
Old 11-10-2006, 02:13 AM
B-Rad's Avatar
ok how do i buy bt pro?
Old 11-10-2006, 02:58 AM
Rock4XFab's Avatar
Oh Chris ATTENTION Chris.... better jump before I steel your sale...
1-847-672-9653
1-847-544-1823
Old 11-10-2006, 09:09 AM
Call me and I will get you set... 1.651.257.8715
Cris
Old 11-10-2006, 10:15 PM
B-Rad's Avatar
Thanks again Cris :)
Old 11-10-2006, 10:41 PM
Rock4XFab's Avatar
Originally Posted by Rock4XFab
Reason #126
BTW no one was hurt in the making of this sales tool LOL
1-847-672-9653
1-847-544-1823
HTML code is On
