Old 11-03-2006, 05:00 AM
binderbound's Avatar
binderbound binderbound is offline
post your pics of proper welds!
Thought I would throw this out there for the new(and not so new) guys. All your certified or just really good welders, post pics of your good welds(I know you have pics) tell us what type of material, welder, settings, and technique(sp?).
Its art, show it off!
Old 11-06-2006, 09:06 PM
B-Rad's Avatar
B-Rad B-Rad is offline
Ive never had much luck getting pictures of welds, I think my camera is part of it. Unfortunately Im not allowed to take pictures of anything at work so anything I post would just be a MIG weld.
Old 11-15-2006, 07:51 PM
Asshogger's Avatar
Asshogger Asshogger is offline
1/8" 6061 Fan Shroud with a Syncrowave 250.
Old 11-15-2006, 09:20 PM
russellmn's Avatar
That is absolutely gorgeous!
Old 11-15-2006, 11:31 PM
Rock4XFab's Avatar
tig weld shop master 300ac/dc
http://rock4xfabrication.com
1-847-672-9653
1-847-544-1823
Old 11-16-2006, 11:36 AM
$CEEP's Avatar
$CEEP $CEEP is offline
airco dipac 210 MIG. 1/4" plate to 1/8" wheel.
and nowhere near as pretty as some of the guys here
Old 11-16-2006, 02:15 PM
Doesn't look bad to me $ceep....in fact a lot better than most I see where I'm located.
Old 11-17-2006, 07:09 AM
Looks great guys. Keep them coming.
It seems, when I do my best work, I never have my camera. My cell phone pics just never do it justice. I'll try and get something up soon.
Thanks.
Old 12-19-2006, 12:28 AM
Racin_Jason's Avatar
8" split in the bottom of a canoe with a MM3035 spool gun!
Old 12-19-2006, 12:29 AM
Some bumper work I've done.
MM DVI
Old 12-19-2006, 01:41 AM
Both look good Racin Jason! Someone may comment on the vert down on the attachment tab, but looks like you got it burned in good. I do and have done lots of vert down. It's not as weak as most people think if you know how to run it.
Old 12-19-2006, 03:24 AM
B-Rad's Avatar
Originally Posted by Captainfab
.... It's not as weak as most people think IF you know how to run it.
I agree completely
Old 12-19-2006, 10:03 AM
jackalope's Avatar
Originally Posted by B-Rad
I agree completely
X3
All about the heat and the weave!
Old 12-19-2006, 01:38 PM
Wonk's Avatar
Wonk Wonk is offline
How can you be certain it was welded as a vert down? Was it maybe welded flat???
Old 12-19-2006, 01:48 PM
KeithXtreme's Avatar
OFN Member
I had the exact question ...wonk
Chopworx Motor Co.
Business# 918.607.3328
Chopworx.com
Old 12-19-2006, 02:53 PM
jackalope's Avatar
You cannot really tell on the pic provided and further, it doesn't look "too" much like a vert down weld. Typically a vert down weld will wet out at the foot of the welds but be too cold for penetration and thus is where the problem(s) start.
Most V down welds will have a more pronounced inverted "U" appearance. If you look closely, you can see the the very edge a cold spot where the weld is not penetrating.
By controlling the heat and the weave, you can get a much better V Down weld with MIG
As to the question of how you can tell "This" pic was V Down, you can't for sure.--Grant
Old 12-19-2006, 10:47 PM
I welded it together in the position you see it. It's mounted in heavy bumper jig, so yes it is a vertical down weld on the tab and the tube also. The tab is beveled at the base and the mounting bracket is drilled out on the backside and into the tab and is welded there also.
Old 12-19-2006, 11:03 PM
OFN Member
I think it looks good Jason....great job.
Chopworx Motor Co.
Chopworx.com
Old 12-20-2006, 10:09 AM
Thanks.
I know there is a lot of debate about vertical welds and how to do them, but when I weld vertically (down) it doesn't seem to turn out any different than when I weld flat. As far as I can tell the penetration is the same and the weld doesn't appear any different cosmetically. Is there really an advantage to welding vertical (up) as apposed to down? Anybody have any pics of a nice vertical(up) weld? Mine don't seem to turn out too well.
Old 12-20-2006, 02:36 PM
A vertical down weld will typically produce a flat to concave weld which has less elongation as opposed to a vertical up weld producing a convex weld. According to the theory on vertical up welding, it is supposed to produce better penetration than a vertical down. This is sometimes hard for me to believe, since to weld vertical up, you need to turn your machine way down as compared to a flat or vertical down weld on the same material. Of course you are moving a bit slower with a vertical up weld giving it more time to heat the material. I have some pics of some vertical up welds, but they are on my home computer....I'll try and post them up later.
As for vertical down welding, one of the advantages of it is speed. The machine can be turned up fairly hot and the travel speed can be increased considerably. Of course to produce a quality weld in that position and speed takes an experienced welder. During all the years I worked in production shops building wood stoves, pellet stoves, and gun safes we always welded vertical down. On the heavier material, such as 3/16 and 1/4, we would run either .035 or .045 in a spray or semi-spray transfer mode. The only time we had any failures was from an inexperienced welder that wasn't familiar with the process
