Old 07-06-2011, 11:02 AM
$CEEP's Avatar
$CEEP $CEEP is offline
got the axle mostly gusseted up last night. still need to add some lower gussets but need to wait until the coils are in place so i can work around them.
Old 07-11-2011, 10:20 AM
$CEEP's Avatar
and shes a roller.
and apparently im collecting these things now. this popped up on craigs for $200 sat night. ran and got it for $150 sund morning. now i have a matched roof to chop up as well as a super-hurricane 6 to sell, license plate/tailight bracket that i was missing, etc.
Old 07-18-2011, 10:16 AM
$CEEP's Avatar
good weekend.
got the tub set on the chassis Friday night before it got dark.
woke up sat morn and set the fenders/hood/grille in place to see how she looked.
going to have to do some front fender trimming as expected.
then it was time to sling the motor/trans back in and see if i measured everything decently.
it fits. barely. getting a radiator in is going to be fun. need to get motor/trans mounts mocked in place. then back to the shop for final weld then it can start going together for good. not going to have much time to work on it in the next two weeks. but come 8/6 i should be back on it.
Old 07-18-2011, 11:29 AM
$CEEP's Avatar
just updated the cost spreadsheet, after scrapping the MBZ and a bunch of other steel in the yard that i had decided would be used to help fund this project, i'm paying out of pocket now.
total to date: $525
Old 07-18-2011, 04:20 PM
Blind Studios's Avatar
You should totally borrow Drat's "angry" eyebrow.
Looks mean Sceep.
-Jeff
Old 07-18-2011, 05:12 PM
$CEEP's Avatar
Looks mean Sceep.
-Jeff
there aint gonna be enough windshield left to eyebrow once the chop is done. LOL.
Old 07-19-2011, 01:35 AM
bronco's Avatar
bronco bronco is offline
Is there going to be a panhard bar?
Old 07-19-2011, 02:07 AM
Dratwagon's Avatar
Dratwagon Dratwagon is offline
How far do you plan on lowering it ? how about bagging it ?
Old 07-19-2011, 09:06 AM
Good point.
It'd be like an angry squint...... LOL
-Jeff
Old 07-19-2011, 10:19 AM
$CEEP's Avatar
yes.
hopefully i can get it a bit lower. frame is about 6" off the ground now, rear of the tub isnt sitting fully down, need to hack the rear floor out for the axle to come up thru it, then the body will sit about 4" lower in the rear.
probably wont ever bag the rear, but those front coils are pretty stiff and swapping bags in later wouldnt be any big deal.
Old 11-21-2011, 06:13 PM
$CEEP's Avatar
finally getting back to work on this.
loading on the trailer was a PITA with the lack of breakover angle.
got the motor/trans cleaned up a bit. dont think this things been this clean since it left the factory in '81
now that its at the shop its time for motor/trans mounts, brake lines, driveline, gears, steering, fuel.
Old 11-21-2011, 06:22 PM
Tilting the entire trailer nose up can help a lot when loading a low/lowered vehicle. Maybe you could have loaded it without the frontloader? I like your style nonetheless!
Old 01-04-2012, 10:44 PM
rob92xj's Avatar
rob92xj rob92xj is offline
Looks awesome, great build on a budget. I would 4 link and bag it personally just my opinion.
Old 03-27-2012, 12:02 PM
$CEEP's Avatar
just sceeping along.
motor mount
driveline is actually going to go uphill. weird.
rear end is getting buttoned up now. gears are in and setup. new bearings and seals all around. pinion angle set and perches welded on, shocks mounted. probably bend brake lines tonight.
Old 03-27-2012, 12:50 PM
Looking good Sceep
Old 05-15-2012, 11:37 PM
mob505's Avatar
mob505 mob505 is offline
That wagon is going to be SWEET. Hey sceep you still have that huge mog axle buggy
Old 05-15-2012, 11:39 PM
mob505's Avatar
That rear 9 is crazy wide.
Old 10-18-2012, 06:38 PM
Rockcrawlingmudbogger's Avatar
Rockcrawlingmudbogger Rockcrawlingmudbogger is offline
Location: Texas, north of Houston in small town new waverly
Any progress??
Old 01-05-2015, 02:13 PM
$CEEP's Avatar
2+ year update.
Goddamn I am the worlds slowest builder. worked on it for the first time over the holidays.
brake lines finally got run.
picked up a turbo motor. got it in and running:
https://drive.google.com/open?id=0By...cGs&authuser=0
waiting on some fuel lines to show up so i can finish up the hardlines from the cell to the motor, and replace the softlines on the motor.
firewall got patched up and all holes smaller than 3/8" welded shut. leaving the larger ones for now until wiring is done.
3" exhaust got started. rest of the exhaust is on order. hope to finish it up (the exhaust) before next week.
Old 01-08-2015, 10:31 AM
$CEEP's Avatar
soft and hard fuel lines are done.
