Old 04-08-2014, 11:12 AM
I could view everything just great... very kewl bro.. keep up...
Old 06-03-2014, 07:52 AM
lakesmod's Avatar
lakesmod lakesmod is offline
Some progress.
http://s210.photobucket.com/user/lak...?sort=3&page=1
Old 06-03-2014, 12:11 PM
Late and just for what it is worth:
http://www.speedwaymotors.com/Super-...ngs,50985.html
Old 06-03-2014, 03:19 PM
lakesmod's Avatar
I looked at them but the $379 is to much.
Old 06-04-2014, 04:19 PM
Originally Posted by lakesmod View Post
Can you explain what you've made progress on? I looked at the photos but not sure what's changed since you last shared the album.
Old 06-04-2014, 09:37 PM
lakesmod's Avatar
You bet I can explain.
1
Finished the 1" x1" tubing for the dash support.( you cant see it)
2
Made the bracket that holds the steering shaft to the dash support.
3
Made the radiator mount.
4
Used 1 3/4" long nuts welded to a 3/8" plate. That will support the radiator mount.
5
Made a part that bolts to the rag joint and the steering shaft.
6
Made the mount for the V W type 3 steering box.
7
Started to plum the gas line,parts are due Friday.
8
Made and installed the sight gauge.
9
Installed a cross member to support the 2-2"x4" tube that holds the gas tank.
10
Made the straps that holds the gas tank to the 2-2"x4" tube.
Fred
Old 09-05-2014, 12:22 PM
lakesmod's Avatar
Up dated pictures.
http://s210.photobucket.com/?betaEna...postlogin=true
Fred
Old 09-22-2014, 02:20 PM
lakesmod's Avatar
Looks like that link is ca ca. Lets try another one.
<iframe width="480" height="360" src="http://s210.photobucket.com/user/lakesmod/embed/slideshow/"></iframe>
Old 11-19-2014, 12:34 PM
lakesmod's Avatar
It's cold and the garage has no heat.
So lets add up the receipts.
Summit $ 2,214.47
Speedway $ 2,071.07
All others $ 7,878.28
$ 12,163.82
Ever add your receipts
Old 11-19-2014, 01:25 PM
I have added receipts before, but nowadays I only do it in piecemeal chunks (like how much the engine itself cost to build) rather than adding up to a total or maintaining a long-running balance sheet. Summing it all up would make the Mrs. go berserk.
FYI, you can post your photobucket photos directly to the forum. When you select a photo on photobucket, you will see an icon above it that looks like a chain link. Click that icon and you should get a popup. In the section under "photo links", there is one titled "IMG". Click the text below that (it looks like [ URL=http... ] etc) and it will copy the code for sharing on a forum . Then when you are typing on OFN, you can right click and select "Paste" to put that code into your post.
For example:
Old 11-19-2014, 02:48 PM
Editing for money and time spent;
Time ~ 204 hrs
Parts;
'90 stx ranger ~ C$200
'87 stx highrider ranger [flat of beer] ~ C$45 C$245
safety related
cage - pro built C$2000 C$2,245
driving suit - new C$345 C$2,590
helmet - new C$145 C$2,735
alum. seats-used (2) C$300 C$3,035
window net - new C$50 C$3,085
fuel cell - new C$200 C$3,285
fuel cell - a/n fittings C$105 C$3,390
fuel cell - low pressure pump C$105 C$3,495
5 point harness - used C$25 C$3,520
master kill switch + elec. misc. C$75 C$3,595
50' 2/0 wire (used jumper cables-homemade) C$25 C$3,620
__________________________________________________ ____
truck related
rebuilt calipers and pads C$90 C$3,710
shocks - 6 pr used - traded for one aluminum seat (C$150) C$3,710
mig wire C$70 C$3,780
shock mounting C$50 C$3,830
grade 8 bolts, etc. C$50 C$3,880
wd-40, zip discs C$35 C$3,915
fan belt C$30 C$3,945
rad flush + fluid C$30 C$3,975
sandblasting frame C$75 C$4,050
tube 1"x1"x10' C$10 C$4,060
brake flex line C$80 C$4,170
brake hose flex line - f-150 C$20 C$4,190
brake fluid, fuel inj. cleaner, misc. C$20 C$4,210
brake hose 60" hard line, hose locks C$15 C$4,225
sway bar bushing kit C$25 C$4,250
oil pressure switch, oil filter, vacuum caps C$20 C$4,270
elec. solder,fuses, misc. elec. C$40 C$4,310
misc. hose and wire clamps C$25 C$4,335
self-etching primer C$90 C$4,425
fuel; line, filters and menders C$45 C$4,470
fire ext., air filter, bulbs C$35 C$4,505
spark plugs, wires, and MORE filters C$105 C$4,610
anti fatigue mat for seat C$15 C$4,625
wire C$5 C$4,630
29" 8.50/15 tsl's mounted and balanced C$500 C$5,130
Back from the races;
I haven't kept up the running total. I probably have another C$2,000.00 into it and about 100 hrs more.
Richard
Old 11-19-2014, 08:05 PM
Crap I just did it in round numbers and
I figure my 75 will be about $30k not counting labor...
Old 11-19-2014, 08:46 PM
lakesmod's Avatar
Labor $$$$$$
If you could, what would you charge your self ?
Old 11-19-2014, 09:33 PM
In my case I am learning as I go. A pro probably would have a quarter of the time in that I do. So I would say about $12.50/hr for my labor
Old 11-19-2014, 11:33 PM
For the type of build lots of one-off and a fair amount of design time, I'd knock a chunk off shop rate down to say $75/hour.
At that rate, parts and labor would be about $50,000.00 which is the going rate for a brand new truck off the lot... and this one will walk anything new...
Old 12-17-2014, 01:23 PM
lakesmod's Avatar
first drive
I took the first drive last week.
The brakes suck.
I have tried bleeding them with a hose in a jar of brake fluid.
Tried speed bleeders. Tried someone pumping the peddle and opening the valve.
Tried bench bleeding 2 times.
All this and still a mushy peddle and cant lock up the tires.
All in all this RPU is a blast to drive.
Handles like a go cart .
Fred
Old 12-17-2014, 02:05 PM
Don't know if you can but you might try reverse bleeding.
Old 12-17-2014, 02:36 PM
lakesmod's Avatar
How is reverse bleeding done?
Old 12-17-2014, 03:03 PM
You use a pressure bleeder but connect the pressure to the bleeder screw and force fluid back to the M/cyl... Works awesome for Hyd Clutches (Ford Rangers come to mind)
Old 01-14-2015, 11:00 AM
lakesmod's Avatar
I had to get a certified weight before going to the state inspection.
2360# with 1160 #on the front end and 1200 # on the rear .
