Old 01-09-2007, 04:54 PM
KeithXtreme's Avatar
OFN Member
Front A-Arms
Date: Thu Jul 27, 2006 1:38 pm
Subject: Front A-Arms anthonymwindle
I am just about to build the front a-arms, but don't want to spend the
money to buy the Badland Buggy Jig. Does anyone have any photos of how
they built theirs. Also, I am going to bring the A-arms closer (6"
instead of 9 and 3/4") togother and then lengthen them to try and get
more travel. Any pics/suggestions are welcome.
Anthony
#1824 From: "a121748" <Researchweb@AOL.COM>
Date: Sun Jul 30, 2006 5:27 pm
Subject: Re: Front A-Arms a121748
--- In badlandbuggy@yahoogroups.com, "anthonymwindle"
the
how
> Anthony
Fresno, CA here - I have built front ends for this buggy and others I
have built before. I used tubing holders made from aluminium sheet and
made the base from either 3/4" plywood or aluminium. This allows the
maker to make any length A-arms they want.
If you have any questions, you can contact me at researchweb@aol.com
and my name is Bret.
I have also made a center drive section that is limited slip using
automotive differentials and installed a reverse gear using an
automotive starter to drive it.
Hope this helps!
Bret
#1826 From: Anthony Windle <anthonymwindle@yahoo.com>
Date: Mon Jul 31, 2006 2:12 pm
Subject: Re: Re: Front A-Arms anthonymwindle
Thanks for the tip.
I think I am going to buy a piece of 1" thick Stell that's 36"X36" so I can make J-arms... We shall see...
Anthony
the
how
> Anthony
Hope this helps!
Bret
#1829 From: Ronald Sweere <steelworker19710@yahoo.com>
Date: Mon Jul 31, 2006 6:22 pm
Subject: Re: Re: Front A-Arms steelworker1...
Will that throw off the algnment of the rack and a arms? Possibly giving a toe in/out at each end of the wheel travel?
Ron Sweere
Oxnard CA
the
how
> Anthony
Hope this helps!
Bret
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1ΒΆ/min.
#1825 From: "paul cather" <pcather@cox.net>
Date: Sun Jul 30, 2006 6:04 pm
Subject: Re: Re: Front A-Arms pcather23964
Hi Bret,
Have any pictures of your A-arm variable length jig? I'm at the point were I need to make the front and rear suspension for my ST2-long travel.
I'm using VW type II CV's, so I know the spacing for the rear suspension will probably have to change.
Thanks... Paul
----- Original Message -----
To: badlandbuggy@yahoogroups.com
Sent: Sunday, July 30, 2006 5:27 PM
Subject: [badlandbuggy] Re: Front A-Arms
the
how
> Anthony
Hope this helps!
Bret
#1830 From: Researchweb@AOL.COM
Date: Mon Jul 31, 2006 5:17 pm
Subject: Re: Re: Front A-Arms a121748
not really - just have to adjust the length of the tie-rods to the correct length.
If not, you might get a lot of bump steer
Bret
#1831 From: Researchweb@AOL.COM
Date: Mon Jul 31, 2006 5:19 pm
well work but is a lot for just a jig.
Remember, all you want to do on the jig is to tack weld the arms well and then weld them separate from the jig. The jig is just for alignment tacking.
Bret
#1851 From: "jaco_d" <jaco_d@yahoo.com>
Date: Wed Aug 30, 2006 9:29 am
Subject: Re: Front A-Arms jaco_d
Hi Anthony
Have you sorted out that jig?If you havent, you can send me the
drawings of the a arm and the sizes of tube your gonna use.Then I'll
draw a jig for you that you can lazercut or waterjet.
Jaco
Chopworx Motor Co.
Business# 918.607.3328
Chopworx.com
Old 09-05-2008, 01:34 PM
Pants's Avatar
Pants Pants is offline
Did anyone ever get the dims for a front a-arm jig?
