Old 01-14-2015, 10:00 PM
metalchef101's Avatar
metalchef101 metalchef101 is offline
newb here
Whats the technical name for the spring part that is on a double wishbone suspension.
Thanks for ya help :)
Old 01-14-2015, 10:16 PM
I got it haha coil springs sweet im learning. Now i need someone to recommend a set of coils i can provide the design of the double wishbone suspension im making for the springs
Your help would be appreciated
Old 01-15-2015, 02:37 AM
29 people so far an they have said nothing
Old 01-15-2015, 02:49 AM
mavereq's Avatar
mavereq mavereq is offline
I'm a newbie here and I honestly can't tell if you're joking or not.
Old 01-15-2015, 03:11 AM
I am being honest unfortunately. Im a fabractor but ice been stuck making pipe handrails and gates for most of my time. But ive recently took a fancy for engines an the like so im trying to learn as much as possible.
Old 01-15-2015, 03:13 AM
**** i must be a complete dumbass if you thought i was joking time to step my game up
Old 01-15-2015, 05:10 AM
310kick's Avatar
310kick 310kick is offline
In automobiles, a double wishbone (or upper and lower A-arm) suspension is an independent suspension design using two (occasionally parallel) wishbone-shaped arms to locate the wheel. Each wishbone or arm has two mounting points to the chassis and one joint at the knuckle. The shock absorber and coil spring mount to the wishbones to control vertical movement. Double wishbone designs allow the engineer to carefully control the motion of the wheel throughout suspension travel, controlling such parameters as camber angle, caster angle, toe pattern, roll center height, scrub radius, scuff and more.
Old 01-15-2015, 05:11 AM
310kick's Avatar
Strut, coil over
Old 01-15-2015, 05:26 AM
Thanks for the info man has any of you ever made an wishbone axle was wondering if you ran into any trouble an also do you think 500mm is ok for the upper arm an will it be ok if i kept the lower also at 500mm.
Thanks for the feedback
Old 01-15-2015, 11:19 AM
A-arms come in all sizes. What are you building them for? How heavy? How much power? How much travel of the wheel?
Old 01-15-2015, 11:51 AM
We only decided 2 days ago so its early stages honestly were going for wishbones cause it looks badass the design of the chassis works out at 2100mm long 660 wide not sure what weight that is it will be made out of 30 box section. As for the wngine my friend wants 600cc or more.
Old 01-15-2015, 09:05 PM
Need to convert the mm to (inches) for the old-schoolers (most of us).
What are we building? How much wheel travel do you anticipate?
Old 01-15-2015, 09:10 PM
I dont even know what wheel travel is man. I never went to school to learn i was just in the right place at the right time an the gut who taught me only showed me how make gates, rails and brackets etc so all i have is the internet to learn which is good it will just take time. We are building an off road buggy im drawing up ideas atm
Old 01-16-2015, 12:12 AM
This is the base frame this will all be made on a flat surface with a jig. When im done im going to start adding my uprights and assemble the frame(is that ok way to assemble the frame). I have 2 more questions does the back wishbone axles need to be there or is there a better option i know of a standard axle on axle hangers welded to the frame but i thought you get better performance out of wishbones. What engine is suitable for the 450x450 box at the rear where the axle is? Can i even have it in a box? Thats all for now i appreciate your fedback guys remember this is my first time designing a buggy i still do not have all the knowledge i need thats why i ask you guys.
Old 01-16-2015, 12:28 AM
Dont know how to add photos fs can yall help with that too lol
Old 01-16-2015, 01:33 AM
Paid membership will enable you to host pics on OFN, Membership costs $20.00/year. Otherwise post your pics to a photohosting website like imageshack. Them copy the "IMG" file of the pic you want and paste it into your thread on this site. Make sure the image isn't too big or small: you can size them before copying.
Richard
Old 01-16-2015, 01:39 AM
Thanks man you saved me there haha thanks
Old 01-16-2015, 01:45 AM
https://imageshack.us/my/images excuse my handwriting guys an gals
Old 01-16-2015, 01:46 AM
310kick's Avatar
http://www.offroadfabnet.com/forums/...ead.php?t=9945
This will show you a picture of what your asking.
Old 01-16-2015, 01:47 AM
Did you take a look richard?
