Old 07-16-2016, 03:22 PM
Just remember to KISS and color code everything after you get it working.
I paint mark the valves and use h/shrink on the hose & fittings so that I can t/shoot on the fly and I don't have to remember anything just run the colors.
Old 07-17-2016, 10:15 PM
AlxJ64's Avatar
AlxJ64 AlxJ64 is offline
Ohh for sure.
Its not super complex but when I run the full length hoses then I'll certainly mark everything. I kept the shifter controller assembly and manifold very compact.
https://www.youtube.com/watch?v=RKT_5nwBJOw
Old 07-18-2016, 12:30 PM
CorkyYounger's Avatar
CorkyYounger CorkyYounger is offline
AlxJ64. Shoot me a message. I can send you my email address, but your box is full.
Thanks
Old 08-02-2016, 11:00 AM
AlxJ64's Avatar
Got the dash brace built. The previous owner had removed it because of his handling pedal and master cylinder setup. I could shake the dash by hand sitting in the truck, so that had to be fixed. This should do the trick. 20 Ga sheet with 1/8" solid driven rivets.
