View Poll Results: How do you drive your tube bender?
Manual or ratchet / cheater bar 59 28.92%
Harbor Freight air-hydraulic jack 63 30.88%
SPX or Enerpac type air-hydraulic 29 14.22%
Electric hydraulic 44 21.57%
Other 9 4.41%
Voters: 204. You may not vote on this poll
Old 07-14-2010, 12:53 PM
What method do you currently use to drive your tube bender? Please respond to the poll and tell us what you think of your drive method.
Electric hydraulic
Other
Old 07-14-2010, 01:29 PM
jackalope's Avatar
Now what are you up to!?!? :-)
Old 07-14-2010, 01:40 PM
Rock4XFab's Avatar
Hydrolic unit from Pro-tools... It works great but Slow for some of the production runs I do.
http://rock4xfabrication.com
1-847-672-9653
1-847-544-1823
Old 07-14-2010, 01:47 PM
Nutz4sand's Avatar
Air over hydraulic or their electric over hydraulic? I only ask cause I am curious if the electric over hydraulic they sell is slow?
Old 07-14-2010, 02:53 PM
I'm currently running an air over hydraulic setup on my JD2 Model 4. It's okay (huge step up from the manual Model 3 I had for several years) but slow. The flip side is that it's pretty easy to sneak up on your bend angle to get exactly what you want. Also, you need a pretty substantial air compressor to run one very much...they need a lot of volume.
I would like to upgrade to electric/hydraulic sometime in the future.
Old 07-14-2010, 03:55 PM
ferociousllama's Avatar
ferociousllama ferociousllama is offline
I run the SPX ram and an enerpack electric pump. It's slow...but it was cheap and it didn't require me making a big cart for it.
Are there more pictures of the "other" tube bender? Thats genius with the winch pulling and turning the die. I'd like to see more pictures of that.
Old 07-14-2010, 03:59 PM
Air over hydraulic. My pump is an old OTC and is a bit slow, but as Graham08said, that makes it easy to sneak up on your bend angle. I've had plans to convert to electric hydraulic, but as little as the bender gets used anymore, I don't know when that may happen.
Old 07-14-2010, 04:24 PM
http://www.offroadfabnet.com/forums/...powered+bender
Old 07-14-2010, 05:13 PM
1sok's Avatar
1sok 1sok is offline
Electric Hydro, 220v, 5 hp, 3000psi hydraulic power unit from an elevator
it also serves as ballast on my bender cart, weighs about 200 lbs.
it was free
bob
Old 07-14-2010, 05:20 PM
Nutz4sand's Avatar
I was standard Protools ratchet lever (sucked) on my 105 and I tried a Harbor "frieght" air over hydraulic long ram jack but figured I was not gonna listen to my compressor that much. Might put the jack in my engine hoist...
So MY benders getting a stand built as I get to it and it has a Haldex 120 volt pump/reservoir feeding a Parker Hydraulic trunion mount cylinder via a woodsplitter type valve.
Pics at eleven. (2011 they way I am going about it!! :] )
Old 07-14-2010, 05:26 PM
Rock4XFab's Avatar
Electric over oil... It is faster then the air and quiter but I still could use a little more speed... No biggy still saving pennies for the Baileigh unit.
1-847-672-9653
1-847-544-1823
Old 07-14-2010, 05:46 PM
Sold my Model 3 with HF ram, worked well upgraded to Model 32 with SPX cylinder, no hydro supply yet, prob gonna use a 120v hydro unit i have laying around
Old 07-14-2010, 06:08 PM
4whlflop's Avatar
4whlflop 4whlflop is offline
I made the Got trikes bender and used the HF air/hydro ram. It works good but is fairly slow. I would like to upgrade some day soon.
Old 07-14-2010, 06:21 PM
shaggy10000's Avatar
custom built electric/hydro.
Old 07-14-2010, 07:09 PM
SPX air/hydra ... I like the slow bending cause I charge by the minute .. also slow bending is less stretch to the tube, therefore less waste....
Dog.....
Old 07-14-2010, 07:16 PM
BDR's Avatar
BDR BDR is offline
I stand there and row the boat.
Old 07-14-2010, 08:55 PM
Row that boat!
Adjustable speed, variable pricing.
Old 07-14-2010, 09:05 PM
dedmetal's Avatar
dedmetal dedmetal is offline
air over hyd trapazoid frame a lot faster than spx cyl. and capable of 90* without repinning
Old 07-15-2010, 04:15 AM
zag's Avatar
zag zag is offline
3 phase 400v 1.5kw built electric hydraulic 4000psi. chain/ram driven.
~270 degrees one shot. plenty of speed.
http://www.youtube.com/watch?v=47QjQpqdMts
Old 07-15-2010, 10:17 AM
RE:Todd's Avatar
RE:Todd RE:Todd is offline
Harbor Freight ram on my JD
