Old 05-01-2011, 08:41 AM
Ukraine Train's Avatar
Ukraine Train Ukraine Train is offline
Looking good! How's the visibility from the driver's seat?
Old 05-01-2011, 09:13 AM
deranged's Avatar
deranged deranged is offline
Good question Ukrain, my helmet is even with the top of the seat. I look straight down the front sheet metal, maybe a few inches above that. With the seat padding, I will sit maybe an inch taller.
Old 05-01-2011, 03:25 PM
thompson85k5's Avatar
thompson85k5 thompson85k5 is offline
That is one sick rig! Great job. And yes, that thing is begging for a rear wing.
Old 05-08-2011, 07:18 AM
deranged's Avatar
Here is a wing I whipped up for it! The axles came on Friday, now I have to find time to install them..lol
Thanks for checking it out!
Old 05-19-2011, 09:55 AM
deranged's Avatar
I took it out for a maiden voyage around the neighborhood, and it did great!! The morse cable for the shifter pulled apart for my shifter, so I have to have one made, instead of the cheap EMPI cable. First gear feels really nice, and pulls hard. I don't have to feather the clutch out like I thought I would to get going. Now I am puting tail lights, brake lights, and running lights in the wing, and mounting up some headlights...man this has come a long way in a year! I can't wait to get this thing in some sand!
Justin
Old 05-24-2011, 10:19 PM
fastg60's Avatar
fastg60 fastg60 is offline
Post some running videos!!!
Old 07-17-2011, 12:56 PM
yfzduner's Avatar
yfzduner yfzduner is offline
Nice build, looks great!
Old 07-18-2011, 04:48 AM
Tappet Head's Avatar
Tappet Head Tappet Head is offline
Justin
Congrats on the build mate, came out well
Old 07-20-2011, 03:03 PM
balterbuilt's Avatar
yaaaay
Old 08-11-2011, 11:56 PM
deranged's Avatar
http://www.youtube.com/watch?v=D7rQp...t=HL1313120777
Here is the long awaited video! Check it out, and let me know what you think!
Old 08-13-2011, 09:28 AM
jeep795's Avatar
jeep795 jeep795 is offline
I'm really diggin that slow motion clip you have at the end!
that thing came out great!
Old 09-08-2011, 06:37 PM
Hollywood's Avatar
Hollywood Hollywood is offline
Great build!
Im curious how those S-10 axle stubs and bearings are holding up?
Old 11-30-2011, 01:15 PM
es1758's Avatar
es1758 es1758 is offline
Hey thanks Bandit... It just so happens that I have a water jet at my full disposal! So the holes didnt take that long. I do plan on skinning it for sure. It will have a small wing off the back, possibly for the radiatiors, but not sure yet. I want to make sure the cap is the highest part of the cooling system. If the rads. work better above the motor, the wing will have the tail lights, and brake lights in it, cuz this pig WILL be street legal!
Justin
I seen you said you have a water-jet at your disposal, what kind of rates do you charge. I need a few brackets cut from 5/8 plate?
Thanks
Old 12-21-2011, 03:57 PM
deranged's Avatar
Thanks everyone! The s-10 axles are holding up great! I have everything torn apart to powdercoat everything. I will add pictures later tonight. @ ES1578, we charge 125 per hour for cutting. If you want me to give you a quote, send me a DXF, and I will let you know. Here is my work e mail. jterrell@priceindustriesinc.com
Old 12-22-2011, 05:45 PM
deranged's Avatar
It's all torn apart! I have parts powder coated, and is all set to have the frame blasted on Tuesday. I am mounting the radiator right in the path of fresh air too! Here are some pictures.
One thing I am changing are the bushings...these were poly, and I am machining delrin ones, with a crush sleeve. The poly ones just flexed too much..
RED! This will be the color of the frame too.
The new rad location..
Sparkle silver arms!
Super duper hi temp powdercoat. good for 1,500 degrees
All ready for the blaster.
Thanks for looking
oh, my graphic designers...LOL!!
Justin
Old 12-22-2011, 06:48 PM
Totally digging the graphics! I think you have something there!!
Old 01-02-2012, 06:23 PM
deranged's Avatar
I got a lot done this past week! The frame was blasted, powder coated, and I am well under way in the assembly! Check it out.
Blasted.
I added some dimple die parts to the upper shock mounts.
POWDER!
After the first bake, and now ready for clear.
Rolling out of the oven.
And that's how its done.
New delrin bushings made and installed.
Today I got the gearbox back in place, and the over flows back in..
Petals, shifters, and lines...oh my!
Rear shocks, limit straps, and the radiator.
Whew, It's gonna be a good week this week....more to come!
Justin.
Old 01-16-2012, 12:27 PM
deranged's Avatar
UPDATES!!!
It is now a roller!
Fresh stainless rotors
Brakes are all in, and bled, steering is also in.
Trailing arms back in place..
Heck, I even threw a motor back in!
I have an aluminum firewall in the passenger compartment, and then I put some insulation on the aluminum, and then a layer of mirrior stainless for the firewall in the engine bay!
It's now a full roller once again!
And this is what it will look like with the vinyl wrap on it! Not bad for a month tear down, and paint!
Thanks for looking!!
Justin
Old 01-17-2012, 03:57 PM
Great job Justin,a credit to you and enjoyable read and viewing thank you
Old 01-17-2012, 04:35 PM
alwaysFlOoReD alwaysFlOoReD is online now
Great build!
You have a glitch, one of your pics of the alum./mirror stainless firewall isn't...it's a double post of the previous pic.
Richard
