Old 11-30-2006, 11:47 PM
Airwolf's Avatar
Airwolf Airwolf is offline
Ranger/Rhino race buggy build
Now that there is a section.......
ID:	1153   Click image for larger version
ID:	1154   Click image for larger version
Old 11-30-2006, 11:50 PM
Are the skins aftermarket or from a factory/stock machine?
Old 12-01-2006, 12:08 AM
Airwolf's Avatar
Skins are factory Yamaha Rhino.
Old 12-02-2006, 12:39 AM
KeithXtreme's Avatar
OFN Member
Freaking awesome.....I love this....
Chopworx Motor Co.
Business# 918.607.3328
Chopworx.com
Old 12-06-2006, 05:40 PM
Airwolf's Avatar
A few updated pics. Nothing too exciting.
Steering rack mocked up, roof/crossbars done, lower a-arms mocked.
ID:	1158   Click image for larger version
ID:	1159   Click image for larger version
Old 12-07-2006, 02:21 PM
smashmetal's Avatar
Fasterbater Mabricator
How much weight is being saved by tubing everything out as oposed to it's stock counterpart?
Old 12-07-2006, 03:40 PM
Airwolf's Avatar
I am hoping to come in around 1400 lb's wet, which is actually a little more than a stock machine. The bigest advantages are strength and handling, both of which will be vastly supperior to a stock machine.(thats the goal anyway.....haha)
Just like with trucks/Jeeps, the factory has to compromise certain attributes to cover a wide range of intended uses, farm work, trail riding, cost etc.
As a reference with regard to handling/suspension. This buggy has 21" of rear travel and will have about 18" front. Compare that to the stock 8-10" and you can see that big air jumps and high speed "BAJA" type riding will be a lot more controlled and safe.
The stock frames need alot of reinforcement , not to mention real roll cage. Some builders go as far as sandblasting the entire stock frame and re-welding /gusseting all the factory joints to ensure strength. I really don't have anything against modifying stock components, but on this build this seemed to be the best option.
Aaron.
Old 12-07-2006, 04:14 PM
Nice use of the dimple die on the steering rack mount. 18-21" of wheel travel on something that size is just insane. That'll make for a fun ride!
Old 01-12-2007, 11:17 PM
Airwolf's Avatar
Here are a few updates. It sure seems like things are moving slow on this one, but I have been swamped lately.
Front suspension geometry figured out and mounted (less shocks and mounts), steering mocked and mounted, foot controls located:
ID:	1355   Click image for larger version
ID:	1356   Click image for larger version
Old 03-22-2007, 02:57 PM
PJC's Avatar
PJC PJC is offline
What are the class rules for UTV's for BITD, SCORE, MDR etc.?
Are they minimal in preservation fo structure, like Class 7 and 8 or ???
Old 03-22-2007, 04:22 PM
Airwolf's Avatar
http://www.utvracingassociation.com/rulebook.html
Old 04-14-2007, 10:46 PM
Airwolf's Avatar
Here are few updated pics....still lots of mock up parts. shocks and axles should be here soon.
ID:	2076   Click image for larger version
ID:	2077   Click image for larger version
ID:	2079   Click image for larger version
ID:	2080   Click image for larger version
Old 04-15-2007, 10:10 AM
CaptAz's Avatar
CaptAz CaptAz is offline
Nice build, great ideas!
One thought from the pics it looks like you wont get much air flow to your radiator. R U going to duct air in?
Old 04-18-2007, 12:39 AM
Crwcompact's Avatar
Crwcompact Crwcompact is offline
Airwolf,,,nice looking build...
Check out Rhinoforums.net as well.
Old 04-19-2007, 09:44 AM
Airwolf's Avatar
CaptAz- you may be right about the radiator. I am eager to see if it gets enought air myself! We really played around alot with different mounting locations, but ulitimatly decided on the location seen for several reasons. If it does run hot, I think we can shroud it and maybe even duct some air if needed.
Crwcompact- I will check out your site.
Thanks for all the replies!
Old 04-19-2007, 09:32 PM
therail's Avatar
therail therail is offline
I hope you have some plans to hop up the motor. I have ridden in a rhino with long travel arms and King shocks, but the motor wasnt enough juice to even think about giving the suspension a workout. however, CBR600rr motors fit in there quite nicely.....
Old 04-19-2007, 10:06 PM
CaptAz's Avatar
That's not a Rhino motor.....
But I goota stick up for them, mine does 60mph, all stock save for a CDI and clutch sheeve.
Old 04-19-2007, 10:48 PM
Airwolf's Avatar
The motor you see in the above pictures is not a Rhino motor, it is a 500 cc Polaris engine. It will be used to dial in the chassis and has been used for mock up.
The eventual engine, shown below is a 700CC two stroke Rotax, rated at 125hp. It should move pretty good... :)
Old 07-04-2007, 10:38 PM
Airwolf's Avatar
Slow yet steady:
Old 07-04-2007, 11:10 PM
Fry's Avatar
Fry Fry is offline
nice work, we sell rhinos and the Ag dealership that I work at. Quite impressive units in stock forum, thought about how cool a long travel full caged rhino would be, and here one is lol.
