Old 11-27-2016, 06:49 PM
Bend Recipe Holder
I wanted something that would keep the bend sheets handy. They always seem to be out of reach, fall on the floor or just not in the right spot. I had an old magnetic indicator base laying around, so a couple of drilled holes in a piece of flat bar, add a clamp and now the papers stay right where I need them in easy view and not falling on the floor.
Old 11-28-2016, 08:52 AM
Good idea! I have the same problem with stuff falling on the floor.
Old 11-28-2016, 09:26 PM
Nice Rory.. I just leave the laptop open while bending... saves from printing...im cheap
Old 11-28-2016, 10:01 PM
Cheap. You have a laptop in your shop? Wow!
What do you set the laptop on???? HUH?????
I don't have any flat surface near the bender to set stuff.
Old 11-28-2016, 11:09 PM
My 2005 xp laptop is only for BT and tech files... the bender is mobile so it goes anywhere. Dont tell me your bender is bolted down
I see plenty of catch-alls, i mean flat surfaces in your shop... do like i do and kindly scoot them to another catch-all
Old 11-29-2016, 11:59 AM
Its only bolted down when I need it for a project or should I say its bolted down until I need more room in that area. My catch alls are all caught up, I need to do a Fall cleanup and recycle and/or dump run. No I don't have any prototype stuff laying around to get rid of.
Old 11-29-2016, 11:30 PM
Originally Posted by R.DesJardin View Post
.... No I don't have any prototype stuff laying around to get rid of.
Liar liar pants on fire!!!
I know youve got some more bling prototype stuff you need to liquidate.... i promise they'll get used.
