Old 10-16-2016, 01:27 AM
Scrambled's Avatar
need bending help
I am needing to bend these steps for a ladder I need to build.
I am needing to plasma cut these out of diamond plate and then bend them.
Would it be easier to cut the parts and then weld the parts together instead of bending?
I have never made these before, so I need a good starting point.
Here are some pictures
http://i1113.photobucket.com/albums/...adder-step.jpg
http://i1113.photobucket.com/albums/...dder-Model.jpg
Old 10-16-2016, 11:13 AM
Aluminum? What grade? Different grads have different bending characteristics aka bend radius. I make parts from cardboard then simulate the bending process to verify it's doable with my brake. Yes often it's easier to cut minimal parts and weld them.
Old 10-16-2016, 04:14 PM
Scrambled's Avatar
R.DesJardin-
Sorry about that. It is steel diamond plate. The whole ladder is made from mild steel.
Steel
Old 10-17-2016, 08:45 AM
You have an ironworker with a small press brake, right? You could do them in one piece if the flanges are wide enough to span the lower vee you need for the gauge of material you're working with. The last little tip on the flange might be a little tricky, but I think you could bend the vertical part of it first, then make the horizontal brakes. You would have a short horizontal weld where it meets the main step, and short vertical welds at the other two corners.
If the flange isn't wide enough, I would cut the vertical flange out of smooth steel the same gauge as your tread plate, bend them up separately, and weld on to the main step.
I always try to make stuff in as few pieces, with as little welding as possible...if it doesn't put the degree of difficulty over the top vs. cutting and welding.
Old 10-18-2016, 10:22 PM
If the flange is not wide enough to span the lower vee, you can place a larger/thinner piece that spans the vee, under the piece you want to bend, then bend the part. You will make a lot of scrap though, one piece of scrap for each small flange bend.
Old 10-19-2016, 01:00 PM
12husky's Avatar
12husky 12husky is offline
On some pieces with complicated bend geometry, we will slot the bend line on the laser so it can be hand bent and then welded. This saves set up on the press versus true bends and saves jigging time versus cutting it all out individually.
Old 10-19-2016, 07:02 PM
That's what I was thinking. Hand fitting all those loose pieces would suck.
You could make a simple bender with 1/2" plate jaws and a handle to stand the flanges up then buzz in the gaps with the hot glue gun.
Old 10-19-2016, 11:12 PM
Can you share why you need a ships ladder?
Those things really complicate a simple task in my opinion.
Look at all those extra parts.
Old 10-20-2016, 09:45 PM
Scrambled's Avatar
I spent a few hours and tried the bending route. Gave up after a pile of scrap. I could not get them all the same. oops.
Did it the hard way. Cut all the shapes out on the plasma table, built a jig on the table and welded them together. It took about 4-5 hours.
Bullnerd- Simple-- it is what they wanted. Give them what they want, not what they need.
Old 10-21-2016, 09:53 AM
That is true.
Old 10-26-2016, 07:12 PM
Scrambled's Avatar
Well here it is.
I get to install it next week.
Old 10-27-2016, 08:23 AM
Final piece looks good! That's much bigger in real life than the drawing made it look.
Old 10-27-2016, 09:56 AM
WOW! Very nice Steve.
I love coming here and seeing the stuff you guys can do!
Old 10-27-2016, 10:18 AM
Nailed it!
