Old 07-26-2016, 06:28 PM
twoslo4five0's Avatar
twoslo4five0 twoslo4five0 is offline
Critique my tube bender design, be gentle my first post
Hello all, thanks for having me on the OFN! Some of you may see me post on several other forums but I finally made it over!
Ok, so I've been bending tube with a rogue fab alpha for a few years. I mostly bend 1.25 SCH 40 or 1.25 .120 wall DOM. Both of which I bend out the same die. As of recently I've been wanting to expand into some different size martial. I really didn't want to buy any more dies, or invest any more into the alpha so I put it up for sale and sold it for 500 (not bad as I have around 700 or so in it new)
This time around I really wanted to go with full hydraulic and not air over hydraulic. This decision isn't cheap as most know, hence why most people don't go this route. This is the start of my build, it will take me some time to complete but I will update it as I go along.
I did a pile of research on benders. I ran across a 1.25 SCH 40 pro tools 105 die semi local to me for 225 bucks so I picked it up. Knowing then I was going to run PT dies I could either go with 3 options. Pro tools, JMR or pro bender. JMR stood out as the obvious choice to me after contacting troy at swag off road and picking his brain. Plus the price was right 249 + 51 dollars shipping on just the bender itself. This is the race line with no handle attachment and you must order it directly from JMR.
Untitled by Jay Gordon, on Flickr
The JMR bender has bushing that hold the arms together when changing dies and the material is 4130 HT 5/8s thick arms. by saving 100 bucks over PT the only thing you don't get is powder coat.
Next I needed to figure out a way to mount it. I wanted a tube roller as well and stumbled into these plans on eBay. 38 pages of detail, definitely worth the 10 bucks. I will have to modify them a bit but its a great start
http://www.ebay.com/itm/Air-hydrauli...Fba6GZaU1ce5EQ
I had a ram that came off a rockwell axle that was totally the wrong ram for the axle. In came that. its a 2.5, 20 inch, 1.5 bore ram. Should be fine for me as I'm not bending any .250 wall or larger.
After that it was time to find a pump. I was looking at one at northern that was 450 bucks and just thought there had to be another option. After shopping around on ebay and using this calculator
http://www.baumhydraulics.com/calculators/cyl_speed.htm
I settled on this pump. http://www.eaton.com/ecm/groups/publ...t/pll_1222.pdf
Specs are
220v single phase 1 HP motor
2 stage pump
5000 PSI limit
2.5 GPM
2.5 GPM @899 or less PSI
.5 GPM @ 900 or better PSI
As you can see the GPM really drops off after 900 PSI. I couldn't find the exact pressure it took to bend .120 wall dom but even at .5 GPM the cylinder will extend to full stroke in 30-40 second which is plenty fast. At 2.5 GPM retraction for repining should be quick and thats really where I wanted to speed. I should be able to bend to 35-40 degrees before repining which is fine by me.
Everything you see in the picture came with the pump. Its was 240 bucks shipped on eBay.
I also bought all the steel and fasteners with was another 121 bucks. I ordered my 4-way valve off eBay as well which was 94 bucks shipped. Everything is brand new, not used. My steel should be in next week and I can get to building. Trying to stay with the cheap aspect of things, I'm into this so far for 982 bucks. I have a connection on hoses so hopefully I will only be in another 100 past that. To build the tube roller (which will come later) my rough math is 714 bucks. Thats for the harbor freight roller and pipe threader plus all the swag add ons. I fairly certain that Im going to be done with this whole project for 2k or less, which is the cost of most hydraulic benders without shipping. I will have both a roller and bender for that price. Stay tuned for more updates.
Add another 60.55 in electrical cord, a 220v switch and a male 220v plug. I went with 10/3 for the cord, though I really only need 12/3 as the motor only pulls 15 amps. I ordered 25' of cord that I can jump off my welder kart as I have an accessory outlet to plug into. If you haven't seen my welder kart, here ya go
Also the 4 way valve showed up this afternoon.
Old 07-26-2016, 06:42 PM
switch, cord and plug showed today
Old 07-27-2016, 09:49 AM
Unrelated, I really like your horizontal bandsaw up on swivel casters! I freaking hate moving mine around and will be making the same cart. Thanks!
Welcome to The OFN.
Old 07-27-2016, 10:28 AM
Thanks man, I can't take the credit I saw it on GJ or PM or something. Another pic for ya if it helps. What i really like about it is, when you need to do a 45, its easy to swivel the saw and then lock the casters. You can feed the material in straight instead of having to worry about having stuff in the way.
Old 07-27-2016, 01:00 PM
Thomo's Avatar
Thomo Thomo is offline
Nice welding cart!
I'll be following this with interest.
Old 08-03-2016, 08:29 AM
AlxJ64's Avatar
AlxJ64 AlxJ64 is offline
Welcome to the OFN!
Man, that 1.25P die sure looks familiar!
I'm digging that you found the pump so fairly priced. I am working out the details on building a DIY medium sized press brake so info like this is very helpful!
Old 08-03-2016, 08:43 AM
I have a decent sized press brake here
Im kind of 1 step forward and 2 steps back. The pump I bought is for a single action cylinder not dual so I'm either going to have to sell it or try to replace just the pump portion. My hydraulics man is looking into it for me. It would be perfect for a press (thats what mine has) as you don't need a fast return but you would have to have a single action cylinder.
Old 08-11-2016, 05:24 PM
I guess I should update this
Got a stand tacked together and the ram mounted
here is why I went JMR (aside from price), you can remove the die easily without the arms falling apart.
1 Shot. Im happy with that as I have 0 dollars in the ram.
Pump mounted and casters on
Old 08-11-2016, 07:19 PM
Is your valve two way? In-Off-Out?
If it is then you won't need a dual acting pump I don't think.
Maybe I'm not following...
I like the progress and the shop.
Old 08-11-2016, 07:47 PM
I got the pump situation straighten out. I have to add a return which I'm going to add in the tank. Im just going to add a bulk head fitting and route a hose down into the fluid as far away from the vent as possible. Low pressure on the return so I don't need to worry about a hose with JIC ends or anything.
Old 08-11-2016, 08:11 PM
Sounds good.
Old 10-13-2016, 09:41 PM
Got my bender all finished up, figured id take a quick vid.
https://www.youtube.com/watch?v=xek803ahC0A
Old 10-14-2016, 03:13 AM
Adam Gardiner's Avatar
Excellent work, looks Great!
Old 10-15-2016, 07:34 PM
Looks good but you seem to have a lot of flex going on,maby brace bender rails back to ram bottom end point or similar
