Old 08-17-2016, 11:16 PM
Bray D's Avatar
Bray D Bray D is offline
This is awesome. Perfect application for the fixture table. I'll be following this one for sure.
Old 08-18-2016, 10:50 AM
stock93's Avatar
stock93 stock93 is offline
Hopefully I'll be able to get back to it soon. We've been overrun in the shop lately. We don't normally work Satudays but we have been working most of them trying to keep up. Having one day off a week kinda cuts short free time for projects. It will be nice to make some more progress on this.
Old 09-20-2016, 03:56 PM
stock93's Avatar
We managed to make some more progress on this. We received all the material for the nose so we started off cutting tubing. After cutting everything, we had to drill 4 holes in 4 pieces of tubing. They need to line up pretty well because there are plates with weld nuts that get slid inside of the tubing to provide mounting points. Our Bridgeport is a great way to do this.
Once the pieces were drill and welded the inserts in, we used a square to lay them out. You can see the directions book in the background suggesting to o do it this way. It sure makes it way easy and quick.
Another sub assembly needed to be made before we could put the nose together. The jig table makes this pretty easy. We had to do several so we put the 90s on to make it easy to load a second set of tubing without having to do a bunch of centering again.
We put some tabs on them and called them done for now.
We cut out this alignment plate on our cnc plasma and bolted it to the inserts that we had welded in previously. This let us line up the sub assembly and the front lower control arm mount.
We rolled it up on it's front so we could put in the spacer tubes. It was close but not quite the correct dimensions we had to pull it in line.
We had to make one more sub assembly before we could put the nose together.
Here's one of the nose pieces with everything all tacked together.
Old 09-20-2016, 09:30 PM
Bray D's Avatar
Awesome documentation. It's looking great. There's no doubt that the effort you're putting into ensuring accuracy now will pay dividends as the chassis comes together. Good work.
Old 04-21-2017, 01:25 AM
stock93's Avatar
Time sure flys by sometimes. I've not been able to work on the buggy as much as I would like. I've had a lot of things that have taken up my time instead of working on my buggy project. We made all the bushings for the front and rear control arms the other day. We decided to give a try making them in our newly accquired VMC. Getting the VMC delivered, setup, and tooled up is one of the things that has taken up my buggy project time. It's also a steep learning curve to go from manual machinery to running a cnc mill.
We cut all the bar stock to length. We cut the piece a bit longer as to have enough to hold onto. The excess was to be machined off afterwards in the second operation.
Here's Jason, my BIL who is building the second buggy, running bushings in our VMC.
Two full sets of bushings done with the first operation.
On to the second operation. This was just facing the shoulder to length and chamfering the holes.
Here's the full sets all done with 5 spares.
We'll be back to bending tube and building the frames shortly.
Old 04-21-2017, 07:25 AM
deranged's Avatar
deranged deranged is offline
COOL!! I am building one myself! I have a decent thread started here as well.
Old 04-21-2017, 11:01 PM
stock93's Avatar
I've been following your build on mbn. Your much farther along than we are. It's definitely cool to watch other peoples progress on their ar51 builds. Good inspiration. Now if I could just find more time to work on mine.
Old 04-22-2017, 06:56 PM
Thomo's Avatar
Thomo Thomo is offline
I don't really have anything to add, just thoroughly enjoying seeing this being built. Keep up the good work!
Old 04-23-2017, 11:07 AM
stock93's Avatar
Words of encouragement and questions are always welcome.
Old 04-26-2017, 01:43 PM
kick ass, can't wait for braaaping pix
Old 05-14-2017, 03:52 PM
stock93's Avatar
Yeah I can't wait to drive this buggy. Unless things change, it's going to progress along slowly as time and money allow.
We started off this round cutting some more tubing.
Sometimes things just don't go as planned.
I of course forgot to order a spare blade last time I ordered stuff like this. Time to try my hand at welding it up. I figured getting it lined up good would be the first step.
These are pretty tedious to weld. I welded it on both sides then ground it down. I heated it up cherry red with a torch to try to anneal it. It worked out and is still on my saw a week later.
There's some odd notches in this part of the frame for the tubing to go through. We set them up in the mill to notch. Keep in mind since we are building two buggies that setup time isn't as much of a big deal if it means getting through the overall parts quicker. It's also hard to argue with the accuracy of using a mill. I didn't take any more pictures of stuff done in the mill but we also used it to drill all the holes in the tubes(10 ea). I'm getting fairly proficient at putting together a quick program to do things like this. I like being able to load a part in the machine and press the go button. We also made the tap plates for the motor mounts in the mill.
Laying out the next frame layer on the jig table.
Here it is all jigged up.
Jason holding up the two frame sections.
Old 09-17-2017, 05:17 PM
stock93's Avatar
It's been to long. We got back to working on the buggies the other day. I had taken a while off due to going to ride in Colorado for two weeks and having to get ready. We made some progress on the frames. They are starting to look like a buggy. Unfortunately all my previous pictures were on photobucket.
IMG_0938 by Griffin93, on Flickr
IMG_0936 by Griffin93, on Flickr
IMG_0935 by Griffin93, on Flickr
IMG_0933 by Griffin93, on Flickr
Old 09-20-2017, 08:11 PM
deranged's Avatar
NICE!! Glad to see you back at it! I should update my thread. LOL
Justin
Old 10-04-2017, 12:47 AM
stock93's Avatar
I'm glad to be back at it. I really want to ride in these some day.
The chassis are starting to get a bit large to drag in and out of the shop by hand. I would rather bring them in on forks when I have a bit of time to work on them. I decided the best way to do something about that would be to build a couple of custom stands to hold them. I'm going to bolt them to the chassis with some tabs that will line up with the mounts for the nerf bars.
First, we cut all the tubing to length and jigged it up on the table.
Then, we welded it all out and cut a top from 1/8" plate. After we're done building the buggies I plan to add extensions to the leg to use these as work benches.
Old 01-22-2018, 12:25 AM
stock93's Avatar
We got the second table welded up. Jason got plenty of welding practice doing that one.
2018-01-07_10-58-06 by Griffin93, on Flickr
We cut some tabs out on our plasma table and got the chassis mounted to the table.
2018-01-19_07-32-28 by Griffin93, on Flickr
We started bending and notching tubing. I've been notching in my bridgeport mill. I had a notcher but it broke. I haven't been real motivated to buy another one when the bridgeport is just about as quick and seems to do a better job. It will also notch anywhere in a bend.
2018-01-16_07-23-14 by Griffin93, on Flickr
It's really handy for notches like this on short piece that are hard to get a plane of bend bracket on. No problem with lining up their rotation.
2018-01-16_07-23-54 by Griffin93, on Flickr
It's also really easy to put a 1-2-3 block on the table to line up multiple pieces. Keep in mind we're building two of these at once. It's nice when everything like this fits together nicely with no grinding at all.
2018-01-16_07-24-16 by Griffin93, on Flickr
Angles are also no problem. Just swing the head. It's 4 bolts to undo.
2018-01-16_07-24-37 by Griffin93, on Flickr
We got the front hoop and top bars stuck on the chassis.
2018-01-16_07-25-10 by Griffin93, on Flickr
It's starting to look like something.
2018-01-16_07-25-27 by Griffin93, on Flickr
