Old 06-04-2015, 02:41 PM
I would say horizontal is most used for me,my ram is small at 40mm piston and im running 180 bar,The diameter of your cylinder will determine a lot,my 40 mm dies fast with 3mmx2" once I go past max leverage point,I may change at some stage or extend the bender arms as my ram stroke is more than needed and I don't have clearance with 2" in first pin hole past approx 60deg,My system is very fast,im not sure what my flow is exactly but according to the pump manufacturer it's 11 european GPM
Old 06-04-2015, 05:40 PM
Adam Gardiner's Avatar
If you need more torque or are up against the power limits of your motor, you can mount the ram further from the center pivot. The tradeoff will be bending speed and maximum bend angle for a single stroke. Given there is such a big difference between 50mmx6mm and more typical tube sizes, you might consider designing in more than one mounting position for the ram. That would allow you to move it further out to increase leverage for high capacity tube or move it in to keep speeds/stroke up for more typical sizes.
A 3" ram at 55bar will produce about 1,900lbf. To get 7,200ft-lb, it will need to be mounted perpendicularly almost 4ft from the center pivot.
Thanks for the reply and data its very useful can i please ask how did you get to these figures please as I've found a online calculator that gave the results for a 3.2" ( approx 80mm) ram with 800 psi as 6434lb force? So was hoping that my choice in ram would work but I may have to re think if I have missed something out
Regards
Adam
Old 06-04-2015, 05:50 PM
You're right; there is an error in my calculation. I'll have to correct later. That's what I do for writing replies between work!
Old 06-04-2015, 06:24 PM
Pressure: 55bar =798psi
Area = pi()*D^2/4 = 3.14 * 3.2^2/4 = 8.04in^2
Force = Pressure * Area = 798 * 8.04 = 6,416lb
Torque = Force * Distance
Distance = Torque / Force = 7,200ft-lb/6,416lb = 1.12ft
Old 06-04-2015, 06:50 PM
Torque = Force x Distance
Distance = Torque / Distance = 7,200ft-lb/6,416lb = 1.12ft
Thanks for the info I'm happy with the figures now and will hopefully start building the frame and getting the ram ASAP over the next few weeks as the time allows
Regards
Adam
Old 03-31-2016, 04:15 PM
Back on this project now. The arms are being bored out to accept a bush. I know the diameter of ram I need just unsure of the length. What length ram do other people use to achieve 90 bend in 1 go. I was thinking of mounting the ram approx 2" off the original bender arms to increase the length slightly to clear the 2" die
Regards
Adam
Old 03-31-2016, 05:20 PM
Got love how some of our projects get side tracked. Thanks for bringing it back.
Old 03-31-2016, 06:29 PM
As the project stands so far
Pin modified for encoder coupling
Arms with local machine shop being bored out to accept bush.
Tank for hydraulic pump 1/2 made
Sourcing hydraulic ram prices
24v solenoid spool valve purchased
Micro controler/ display made
Stand designed will get steel and make soon
Old 04-02-2016, 09:00 PM
kkroger's Avatar
kkroger kkroger is offline
JD sells a mount and fitments for a real hydraulic ram, I bought their bracketry and a cylinder and then tried to cheap out on the pump and ended up buying the power team pump and hose they sell... I went AOH instead of EOH for a variety of reasons number one being I have a LOT of air... I bought an engine Stand Style stand from Trick Tools... I like it. Was in the mindset I want it all and I want it now... had the funds so I bought it.
All that aside SWAG makes a set of brackets that center up the ram instead of swinging it offset... and the HF ram has a longer stroke than I have currently. But I haven't encountered any problems with my setup other than the size of my garage....
Old 04-07-2016, 03:15 PM
Thanks for the reply I'm to far into the build to start buying JD mounts etc I've got a pump which is man enough according to my figures to bend the tube providing I use a 3" ram at 55bar, I probably won't ever bend 2" 1/4 wall tube though, I want to be able to transport the bender without taking a compressor etc.
The main reason I'm going hydraulic is I don't have the room to bolt the bender down anywhere so making it on wheels and jacking bolts to level up is the best option for me,
I also want to achieve a 90 bend without repinning etc,
I have done a few sums based on presuming that I mount the ram so it is right home when the arms are touching
I have allowed for 18" arm lengths but in reality may be shorter,
I have allowed 10 to take up pressure on pipe and 100 to be able to easily achieve 90 after spring back, so calculating it as a isosceles triangle it would be 18" arm length by 110 maximum angle which works out at approx
29.5" stroke length
Does this sound right to other people
Regards
Adam
Old 04-08-2016, 09:22 AM
Name:  2016-04-08 13.12.52-240x258.jpg
Here is the start of the frame it will be on wheels eventually and then have removable stays which will slide up the box section diagonally from the frame if needed
Old 05-04-2016, 11:06 AM
Latest photo
The display works and looks accurate will try to upload video later.
Old 05-04-2016, 11:42 AM
Awesome! Congratulations :)
Old 05-04-2016, 03:51 PM
https://m.youtube.com/watch?v=rW10Tm...ature=youtu.be
Here is a video of it working it does not flicker like the video shows. Once I fit the hydraulics I will tidy it all up. The stand is just for holding it in place thus won't be what im using.
Adam
Old 06-17-2016, 02:06 PM
Laser cut 10mm arms
Will hopefully put a better photo up soon bolted to the bender
Adam
Old 06-17-2016, 02:24 PM
The 2 short arms are extensions to the standard arms and the long arm is the mount for the ram. I'm using a 800mm stroke ram it's 1000mm overall between centers. I'm doing this to keep the pivot point at the centre of the ram. I will mirror the top and bottom extension with the addition of triangulation on the lower arms to stop the weight of the ram twisting anything.
Hoping to get it bolted to the ram this week workload depending
Adam
Old 06-17-2016, 05:29 PM
Looking forward to your updates :)
Old 07-04-2016, 05:38 PM
Had a bit of time tonight to work on the project
This is the support arm for the back of the ram
There is a top cross bar to go with it but it won't be triangulated
This is the extension arms bolted in position
Old 09-06-2016, 05:29 PM
Picked the new motor pump combo up today couldn't source a pump for the motor I have cheap enough. Got a 1.1kw 240v motor with 2.0cc pump so approx 2.8l/min flow rate. And a 6l pressed steel tank with return filter. Just got to mount the pump and tank now and get the hoses made and can try the operation fingers crossed next week we will be able to bend some tube or box section to try the mechanical side of things then I can build a control panel to integrate the display / control side of things
Old 09-06-2016, 07:19 PM
That should make a great power pack. Keep up the great work!
