Old 12-04-2014, 02:49 PM
crashdodson's Avatar
crashdodson crashdodson is offline
fiberglass rod ends
I am trying to build my own fiberglass rod whips. I have searched and searched and I can not find the metal ends that go on fiberglass stock/rod. I am looking for different types of fiberglass rod ends. I can find fiberglass rods with ends already on them, and bare fiberglass rod stock...but I can not find just the ends alone. I am looking for ends that would slip over the fiberglass rod and be bonded with epoxy and have threads at the other end. Like you would find on a CB antenna. Anyone know what these are called or maybe where I can find them?
Old 12-04-2014, 04:36 PM
Hello Crash.
You will have the best luck (I hope) if you look for something called a "Ferrule".
Depending on exactly what you are looking for you could have the simple part you describe for made by someone with a lathe.
Good Luck and welcome to the OFN.
Old 12-04-2014, 10:13 PM
http://www.castbullet.com/makeit/rod.htm
Old 12-04-2014, 10:16 PM
Here ya go:
http://www.mgs4u.com/shallow-water-boat-anchors.htm
Old 12-04-2014, 10:18 PM
Another here: http://www.cablelaying.com.au/produc...ing-equipment/
Old 12-04-2014, 10:19 PM
The search term that worked or me is "fiberglass rod coupling"
Old 12-07-2014, 01:45 PM
kkroger's Avatar
kkroger kkroger is offline
Check roll your own fishing rod supplies too.
