Old 12-04-2013, 08:52 PM
Willie UTV INC.'s Avatar
Willie UTV INC. Willie UTV INC. is offline
Tig Welder - Fabricator - Wanted (Gilbert/Mesa Az)
East Valley Fab shop looking for experienced TIG WELDER for Steel Tubing and Aluminum .... First and foremost we are looking for People that can Tig weld so if you have not tig welded recently dont apply as you must be able to tig weld. We are also looking for a fabricator with skills in tube fabrication, aluminium sheet metal work and ability to design custom one off parts. Must be proficent with typical shop equipment, manual mill, lathe, shear, tube bender, sheet metal brake etc. We are predominately an offroad fabrication manufacture, building suspension systems for UTV's, roll cages, bumpers as well as job shop projects. Must be a self starter. Mechanical knowledge a plus. Must be versatile and willing to take on a varaity of projects.
Please apply in person for this position if you possess the skills required above at:
UTV Inc
1656 N Banning
Mesa, AZ 85205
Between the hours of 8AM to 11AM and 1PM to 430PM. Ask for Craig.
Interview will include a TIG welding test, so applicant must provide own welding helemt and gloves at time of interview for welding test. Welding will be on ROUND TUBE, so if your skills are not proficiant at welding ROUND tube, please do not apply.
Interviews will be given daily until until all postions are filled.
Please test the battery in your helmet prior to applying for the position as we do not keep batteries on hand for other employees, so we will not supply them for you.
