Old 04-30-2008, 05:16 AM
Jpfab's Avatar
Jpfab Jpfab is offline
What is a 1930's flathead worth?
I have aquired a 1930's car that was converted to a pulling tractor. It has a ford flathead with everything but the starter and 3 carbs. A manual tranny and a narrowed rearend. All of the peddles are in it and it has the orignal 4 port radiator to feed the double fuel pumps of the flathead.
It is supposed to be free, but I haven't put a wrench on it. I put it on ebay http://cgi.ebay.com/ws/eBayISAPI.dll...cSELL.m315.lVI
And not getting much intrest.
Old 04-30-2008, 10:11 AM
Bonehead's Avatar
Bonehead Bonehead is offline
I have seen flatheads go for 400-800, but they are usually freed up and may even turn over. The tractor thing you have is known as a doodlebug. Look up google images "doodlebug tractor" and you will find hundreds of them. A cool old piece of history.
Old 04-30-2008, 02:08 PM
Scooterinvegas's Avatar
Scooterinvegas Scooterinvegas is offline
You need better pictures. I cant get an idea would it looks like. Does it even have wheels?
Old 04-30-2008, 07:30 PM
Jpfab's Avatar
I tried to add pix to the auction but it wouldn't let me.
Old 04-30-2008, 08:47 PM
METAL TWISTER's Avatar
The AB flat heads bring a little more $ and are more sought after. Look on the head for the letters AB. If its there be sure to exploit it in your ads. The first year for the flat head was 1932, The AB's didnt arive until the late 40,s and 50's. It looks like an early flatty... Good luck. Id say if you can get $600.00 for it your doing well. But then again, Im an old dog and have given away more of those things than I care to remember... I think.
