Old 01-02-2008, 03:23 AM
Twisted Minis's Avatar
Yeah I have the die for it, and even have some extra bag plates here. Lol.
Old 01-02-2008, 10:52 PM
Old 01-02-2008, 11:59 PM
balterbuilt's Avatar
you took those pictures at the jc parking structure haha. you have extra bag mounts eh...crunch, grrr, bang, sputter...that's what it sounds like when the gears start turning in my head :-P
Old 01-03-2008, 12:21 AM
Yes I did, and yes I do.
I have extra upper and lower plates. I even have an extra bag you can use for mock up. I also have a "bag jig" that bolts in place of the bag so you can build the brackets with the bag fully compressed.
Old 01-03-2008, 12:55 PM
CoryHinsz's Avatar
CoryHinsz CoryHinsz is offline
You will be in the shop for quite a while getting that bed straight. As rough as it is, was it a work truck before? I do like them low; I have a '67 C10 that is bagged and clipped with 20's that lays the rockers on the ground.
Old 01-03-2008, 03:47 PM
Believe it or not thats the straightest bed I could find for the truck. The bed that came on the truck was a lot worse. This bed isn't all that bad, just has a few dents coming from the inside since they are angle wall beds. You can tell they put something in the bed and didn't strap it down and let it slide into the sides. But I'm not doing the bodywork. I don't do that.
The difference between my bed and yours, is that your bed would be hard to find because everyone wants it. Mine is hard to find because people crush my bodystyle truck on a daily basis.
Old 01-27-2008, 03:18 AM
This is pretty much the reason why I do this...
Old 01-27-2008, 12:44 PM
KEGGER1454's Avatar
lookin good....but i wanna see some SPARKS!!!!!!!
Old 01-27-2008, 01:22 PM
Ladderbar's Avatar
Have you ever messed around with unequal control arm length to try and even out the camber when in the "labomba" mode?
Old 01-27-2008, 02:20 PM
russellmn's Avatar
Most of the time you can't go any more positive on the camber while that low or you'll hit the inside of the fenders. Might get a little bit more, but not much...
Looks good TM, you're going the wrong way, but looks good.
Old 01-27-2008, 09:45 PM
Is The License Plate Mounting Location Legal?
Old 01-28-2008, 03:54 AM
No. Lol.
I'm messing with it now. I'm designing a new front suspension that will get less camber change throughout the travel. Something around 5 degrees laid out, 1 or 0 all the way up. Also narrower so I can turn like that.
