Old 05-01-2007, 06:38 PM
SNKBIT's Avatar
SNKBIT SNKBIT is offline
Very impressive ZT! Goes to show that vertical downhills aren't such a bad thing.
Old 05-08-2007, 12:21 AM
Sleeper's Avatar
Sleeper Sleeper is offline
Those welds are awesome. Can't wait to get rid of my tired Cambell Hausfeld (I didn't know they even make welding machines) and get a real machine.
Old 05-08-2007, 12:40 AM
ZTFab's Avatar
ZTFab ZTFab is offline
Thanks for the comments!!
- Paul
Old 05-12-2007, 11:27 PM
ddement's Avatar
ddement ddement is offline
I want to play
Here is a crappy cell phone pic..304L stainless tig, 1/8" wire, about 105 amps.
Old 05-13-2007, 01:14 AM
balterbuilt's Avatar
that is sick ddement
Old 05-13-2007, 01:38 AM
Thats a better pic than I get out of my digital camera. lol
Nice weave!
Old 05-13-2007, 01:47 AM
ddement's Avatar
Nice weave!
Thanks guys
Old 05-13-2007, 07:59 AM
TitanFab's Avatar
TitanFab TitanFab is offline
Pure gold, I like the purtty colors.
Old 05-13-2007, 09:17 AM
KILLER"B"468's Avatar
KILLER"B"468 KILLER"B"468 is offline
That is rockin
Old 05-13-2007, 10:54 AM
Chase 2's Avatar
Chase 2 Chase 2 is offline
Originally Posted by the flea View Post
New to the forum, first post. Looks like a great place to hang out.
Beautiful welds above. Jeeze, I wish I was a fraction as good on the MIG.
Here is my TIG.
Lincoln PT225, with pure Ar, 2%Th, 65 ish AMPs, ER70S2 (only as needed).
Cant' wait to read the rest of the posts here.
Looks pretty good. Not trying to bag on you, you are real close, but personally I think the weld looks small and undercut.
Old 05-13-2007, 10:55 AM
Chase 2's Avatar
I want to play
Nice cup walking.
Old 05-13-2007, 06:14 PM
phaxtris's Avatar
phaxtris phaxtris is offline
im in agreement with you, the welds look way to small
Old 06-02-2007, 06:28 PM
Trebor's Avatar
Trebor Trebor is offline
Fabrication apprentice
Hello, Some of these welds are pure porn. With no formal welding training I am a little confused by some of the terminology. What is stiching, circles, sharks teeth, and triangle. It sounds like how you may be moving the torch. I am not sure when you would do any of these techniques. I have always just moved down the center adding filler. If I had a wid gap to fill I would just make multiple passes. Any information with some detail would be appreciated.
Old 06-02-2007, 06:33 PM
stitching is using multiple small welds spread out over a surface. It could be for somethign that doens't need a bead down the whole surface area or somethign that you don't want to warp so you place an inch and a half weld every 6" or so until they overlap to keep from overheating the material. Circles i believe were being refered to by the oscilation of the MIG gun as you weld it creates a nice looking strong weld. Sharks teeth are another form of MIG weld and it also referes to the movement of the gun, it is a zig zag motion that looks something like a sharks tooth layout if you were to recreate it on paper. Filling gaps is lame! hahahha
Old 06-13-2007, 01:51 PM
Halibrand's Avatar
Halibrand Halibrand is offline
I want to play
Anyone want to know why welding this flange in a vice is 100x's better than welding it on a flat steel table?
The machined surface on the bottom can be ruined by the grounding arc that passes from the grounded table to the flange part. Basically, youre shiny perfect welds will be useless if the flange doesnt seal properly!!!
Great job!
Old 06-13-2007, 02:08 PM
AndyLynne's Avatar
AndyLynne AndyLynne is offline
Lightbulb
Great job!
Halibrand brings up a good point about locating your ground in the proper spot. If you are ever welding or even tacking an assembly together where you have ball bearings or roller bearings involved, make sure your ground doesnt have to pass through your bearings or the arc may give said bearings a short life..not to mention if its an older workpiece with grease in the bearings, you could possibly set the grease on fire.. just my thought for the day...
Old 06-13-2007, 03:09 PM
ZTFab's Avatar
You mean like this? Looks like it already happened.
Old 06-13-2007, 03:40 PM
dabeldesign's Avatar
dabeldesign dabeldesign is offline
I noticed that earlier too...hmm... Oh well, still better than I can do; I suck at walking the cup.
Old 06-13-2007, 04:07 PM
suzota's Avatar
suzota suzota is offline
your weld make my efforts look awfull.
i best not post any on here or you will all laugh at me.
Old 06-13-2007, 05:20 PM
Halibrand's Avatar
That spot isnt really of concern. It can be cleaned up fast and easy. If it was inside the bolt hole, then you better make sure its cleaned GOOD before dropping a bolt through there.
If that arc was on the bottom of the flange on its machined seal surface, then you have problems. Just like that picture floating around the net where the "fabricator" put his welding ground on the rims of his buggy while he was welding on the frame- sending the arc right through the bearings and races.
