Old 12-21-2006, 12:30 AM
Here's some pics of a couple of vertical up welds. They certainly aren't perfect, but not too bad for not having done any vertical up for about a year.
The pic on the left as you can see also has a horizontal weld. The pic in the center has vertical down welds and of course flat welds
ID:	1224   Click image for larger version
ID:	1225   Click image for larger version
Old 12-21-2006, 12:46 AM
liketofab's Avatar
liketofab liketofab is offline
Nice !
Old 12-21-2006, 01:09 AM
rustynuts's Avatar
rustynuts rustynuts is offline
Here are a few from my Sandrail that I built.
ID:	1234   Click image for larger version
ID:	1235   Click image for larger version
Old 12-21-2006, 11:31 PM
pneufab's Avatar
pneufab pneufab is offline
One day I will try and get some decent TIG welds. Don't beat me up too bad!
MM210
t
Old 12-22-2006, 02:22 AM
Tuckinrim's Avatar
Tuckinrim Tuckinrim is offline
Originally Posted by Captainfab
According to the theory on vertical up welding, it is supposed to produce better penetration than a vertical down. This is sometimes hard for me to believe, since to weld vertical up, you need to turn your machine way down as compared to a flat or vertical down weld on the same material. Of course you are moving a bit slower with a vertical up weld giving it more time to heat the material. I have some pics of some vertical up welds, but they are on my home computer....I'll try and post them up later.
A vertical up weld is the strongest weld to do.The way you do the weld creates the peno though.When you start you are suppose to weld one side of the joint for a few secs quickly move to the other side then hold for a few secs.Then move up and down like a triangle so you are just above where you started.If you know what i mean.Then you just repeat.So you will be making little triangles.We tested and broke all our welds with a press and vertical up will rip most of the plate away when broken.Hope this helps.
Old 12-22-2006, 04:19 AM
B-Rad's Avatar
B-Rad B-Rad is offline
I REALLY need to get a better camera, tried to take a bunch of pics at work but this is the best I got.
Its a submerged arc weld on carbon steel.
Old 02-20-2007, 02:52 PM
Loopy's Avatar
Loopy Loopy is offline
Mad Welshman
I can't believe this thread has been running nearly 4 months and this is the first chance i've had of posting up a pic (can't take pics at work)
I do have an excuse........
A recent fabrication (yet to be trail tested)
Ok end of excuses......
Hybrid mig welder
*0.8mm (.032") mild steel wire (damn copper coated)
*5mm mild steel plate (.20" 3/16+)
*240v 50Hz
*set at 110A / 21v roughly
*70% Argon / 25% Co2 @ 15lpm (.5 cfm)
*torch at about 80* push
*tip to work distance 8mm (5/16") roughly
*50% overlapping circle weave
*90% done in "normal" position
(click on pics for larger versions)
Name:	OFN winch mount top.jpg
Name:	OFN winch mount corner.jpg
And to prove i'm only human........
Name:	OFN winch mount weld close.jpg
No concavity but some underfill going on here, Getting lazy
Give me 75% argon / 23% Co2 / 2% O2 gas any day over this stuff.
Note the copper slag on the weld, the steel was clean of any scale before welding, that crap is from the wire alone !!!!
Old 02-20-2007, 07:37 PM
phaxtris's Avatar
phaxtris phaxtris is offline
Ive been snappin some pics around work lately, its been slow so i have no mig or ss (other than the heater)
an intake manifold i built for a guy down in the states, quick job
http://www.putfile.com/pic.php?img=4819717
22g stainless, tig
http://www.putfile.com/pic.php?img=4819716
Cantilever assembly, sched 80 alum pipe, slightly cold
http://www.putfile.com/pic.php?img=4819715
Cable pass though, part of a larger assembly, .100 matl
http://www.putfile.com/pic.php?img=4819714
hopefully it will pick up in the next little while and i can get pictures of some fancyier things
took a pic of some mig stuff i did today, falcore 96 .045 dual sheild wire, i hate this wire with a passion, but its the only shit the machines are loaded with
http://www.putfile.com/pic.php?img=4826976
and some more tig work, .200tho material
http://www.putfile.com/pic.php?img=4826975
Old 02-28-2007, 02:59 AM
WolfMetalFab's Avatar
WolfMetalFab WolfMetalFab is offline
I think i got my "ugly" mig welds down good
Old 02-28-2007, 09:43 PM
KILLER"B"468's Avatar
KILLER"B"468 KILLER"B"468 is offline
MM210
t
Nice that is the look I want to learn.
Old 04-21-2007, 01:50 AM
balterbuilt's Avatar
Old 04-21-2007, 02:47 AM
section525's Avatar
section525 section525 is offline
Niiice!
I need a welding table. Bad.
Old 04-21-2007, 10:59 AM
thanks, but i odn't have a welding table. i welded that on the ground, right where it is in the picture. You can see a bunch of scrap in the background on the floor :-P
Old 04-21-2007, 02:43 PM
section525's Avatar
Maybe I should try that.
I weld with the piece clamped in the vise. (Didn't weld the shackle at this angle though).
Old 04-21-2007, 05:26 PM
i have a 1 1/4" thick custom ground welding table at the shop I fab at, it's 6 foor by 10 foot, and i still weld lots of parts in a vise. There's no shame in that, vise's are excellent tools for holding parts stable. Welding at that angle is no probelm either, a good welder can weld any part anywhere any time. I prefer a bit of an angle sometimes, it can be helpful. At home i have a well scorched wooden table (ugh).
Old 04-21-2007, 06:33 PM
TitanFab's Avatar
TitanFab TitanFab is offline
1 3/4" x .250 dom and kieths inserts.
Old 04-21-2007, 08:16 PM
the flea's Avatar
the flea the flea is offline
New to the forum, first post. Looks like a great place to hang out.
Beautiful welds above. Jeeze, I wish I was a fraction as good on the MIG.
Here is my TIG.
Lincoln PT225, with pure Ar, 2%Th, 65 ish AMPs, ER70S2 (only as needed).
Cant' wait to read the rest of the posts here.
Old 04-21-2007, 10:05 PM
TitanFab's Avatar
Welcome to the forum flea, nice weld, very nice cope.
Old 04-21-2007, 10:33 PM
KeithXtreme's Avatar
OFN Member
Hey Brother....your weld looks good, but it looks like you did not push the insert in all the way....with the bevel built into the insert you should only have about an 1/8 gap....
Just curious...
Chopworx Motor Co.
Business# 918.607.3328
Chopworx.com
Old 04-21-2007, 11:01 PM
TitanFab's Avatar
No, Its pushed all the way in. I beveled the dom tubing and that is actually just the first tig root pass. I put one more pass on it to fill it in. Just did not take a pic.
