Old 07-02-2012, 05:39 AM
johny5's Avatar
johny5 johny5 is offline
Got the seat and drive shaft issue sorted.
Old 07-02-2012, 05:43 AM
johny5's Avatar
I did a little tube work in the front too.
Old 07-03-2012, 02:40 AM
johny5's Avatar
Played around with the steering column today . I'm liking all the visibility
Old 07-03-2012, 04:42 AM
Good work again Johny,love it
Old 07-03-2012, 07:11 PM
RogueFab's Avatar
RogueFab RogueFab is offline
This is turning out great!
Old 07-27-2012, 02:40 AM
johny5's Avatar
Been working on it again , hoping to have it a roller and off the bench in the near future .
Old 07-27-2012, 03:10 AM
Tappet Head's Avatar
Tappet Head Tappet Head is offline
Nice Build man, How do you go about reversing the output on the transfer case
Old 07-27-2012, 03:32 AM
johny5's Avatar
Thanks
I'm running a honda front wheel drive engine and transmission/trans-axle turned sideways,
so instead of the transmission out-puts going to the cars front wheels , they go to the toyota diffs
So technically no traditional t case . I wont have a high range/low range capability.With diff gearing's it should be a good crawler , and have a good cruising speed , hopefully a comfortable 40mph
Old 07-27-2012, 09:25 AM
Cheers man, now all the bits fit the Puzzle, Seen a lad do similar in a 4x4 mini buggy, drove a centre diff via a chain drive out to another set of diffs.
Old 07-27-2012, 09:27 AM
roco's Avatar
roco roco is offline
nice work. really liking this build. giving me bad ideas.
Old 07-28-2012, 01:31 AM
Mate you've inspired me to do the same after my Mini buggy.
I had an Idea last night, to make an easy Dig unit ( rear drive lock out) why not put a brake on the drive shaft, and leave the centre diff open?
Old 07-28-2012, 06:02 AM
More nice work Johny,love the old lathe,did you sand or do you have some kind of radius cutter?
Old 07-28-2012, 08:12 PM
johny5's Avatar
Thanks guys , I have an idea for a drive line disconect but there's not a lot of room for disk brake ,
The lathe is an old peice of junk but comes in handy , one day I will have a real lathe
The knuckle ball had some bad grooves in it from the 450,000 km on them . I welded up the groove and ground them down then polished them on the lathe
Old 07-28-2012, 08:50 PM
johny5's Avatar
mounted up some tires last night .
Old 07-30-2012, 06:12 PM
RogueFab's Avatar
What are you doing the modified knuckle balls for? Why change them?
Old 07-30-2012, 08:14 PM
johny5's Avatar
They need to be flipped 180 on the housing because the front diff is now in the rear , I welded up the wear marks from the felt seals,then polished them , the cool part was the gear set fits right in after the flip with out any drilling and taping of the studs
Just have to re arrange some of the longer studs that hold the third
Old 09-09-2012, 09:41 AM
Hello Johnny,how you getting on with this,any more progress?hope all going well
Old 09-09-2012, 10:01 AM
johny5's Avatar
I haven't done much with it lately .
Was messing with the rear axle being badly bent , almost have it where I want it now but got working on another guys buggy in the shop , hoping thats done in the next few weeks and then I'll be back at it again.
Old 09-13-2012, 08:15 PM
Thanks
I'll be waiting
Old 09-20-2012, 03:25 PM
OSCS's Avatar
OSCS OSCS is offline
Looks awesome! How much do you think you'll have it in once it's complete?
