Old 06-15-2011, 11:29 AM
Peter H's Avatar
Peter H Peter H is offline
Hood finished....
Old 06-15-2011, 04:42 PM
fordpickupman's Avatar
fordpickupman fordpickupman is offline
Hood
I like it.....
Old 06-20-2011, 12:10 PM
Peter H's Avatar
Old 07-12-2011, 06:18 PM
Peter H's Avatar
Been busy with some rattle cans......
Old 07-12-2011, 10:39 PM
crodasky's Avatar
crodasky crodasky is offline
your rig inspired me to extend the cab of my yota
Old 07-13-2011, 12:34 PM
Peter H's Avatar
Thanks, that means a lot to me!
Old 07-13-2011, 01:17 PM
Great job Peter! I love all the details you put into the hood. Also like how the cage & fender bars tie into the cowl. What is the wheeling like in Belgium?
Old 07-13-2011, 01:49 PM
Peter H's Avatar
Wheeling in Belgium is very poor.........
Only standard vehicles are allowed in traffic. Even a bigger tyre is illegal...
We can only wheel in offroadparks which are only 3 left in Belgium and they are not very big....
We always go to France or Germany. Their offroadparks are bigger and more of a challenge. In Belgium is the surface flat.
The purpose of my build is to compete in offroad races/trophy's in Romania and Croatia.
Over there is free offroading still allowed and the nature is magnificent.
Look on Youtube for : TAT Transylvania adventure trophy , Croatia trophy , Istra challenge.....
The only downside is the distance. I'll have to travel 1800 KMs with a trailer....
Old 07-13-2011, 04:27 PM
Mopars 4 Life's Avatar
lookin good dog!!!!!!
Old 07-18-2011, 01:39 PM
Peter H's Avatar
What kind of tube or hose should i use to connect the radiator in the back?
Steel tubing rusts inside and rust kills the water pump.
Diameter should be between 30 and 35 mm. (1" 1/4?)
Any suggestions?
Old 07-18-2011, 10:34 PM
SteveL's Avatar
SteveL SteveL is offline
Any suggestions?
Steel tube won't rust if you use the appropriate coolant with a de-gas bottle. My 2.0L Pinto engines look like
new cast iron on the inside... 50/50 mix, de-gas bottle, no air in the system...
Old 07-24-2011, 09:56 AM
Peter H's Avatar
I'm going to use galvanized steel tube and, as SteveL wrote, appropriate coolant.
Old 07-30-2011, 05:46 PM
Peter H's Avatar
Bended some galvanized tube:
Connected with silicone hoses.
Radiator cleaned,
Tubing connected to the engine,
Radiator and fans installed,
Radiator connected. The temp sensor needs a reduction ring and the expansiontank is not at it's final place yet, but the coolingsystem is getting there....
Old 08-14-2011, 05:09 PM
Peter H's Avatar
Fuel tank finally gets it's place. It will be covered for security. Donor was a Mitsubishi pick-up truck. It holds 90 Liters.
Rear mudflaps done. Just have to make holes for the airshocks.
Front mudflaps cut, but not installed yet.
Old 08-27-2011, 06:43 PM
Peter H's Avatar
Original roll bar cut to pieces and transformed into something useful.
Only tacked in to place. The real welding will be done by a specialist...
Old 09-19-2011, 05:06 PM
Peter H's Avatar
Some plumbing....
Starts to look like a racing car....
Old 09-21-2011, 11:29 PM
Your truck is looking fine! In my race series having a fluid line inside the cab is a major no-no. Have you checked with your sanctions rules?
Good job so far,
Richard
Old 09-23-2011, 07:15 AM
fal308's Avatar
fal308 fal308 is offline
Is your radiator highre than your thermostat?
Old 09-25-2011, 05:38 PM
Peter H's Avatar
Fuel tank casing reviewed. Wooden panels replaced by metal and filler hose rerouted.
Fuel lines, fuel filter and filler hose will be covered with sheetmetal.
Front mudflaps finished.
Thermostat and radiator are approx the same height.
Old 09-26-2011, 02:56 PM
Peter H's Avatar
Japanese spaghetti
