Old 11-08-2008, 01:11 AM
Some nice work you're doing Dq......
Old 11-16-2008, 11:37 AM
Dqracer's Avatar
Dqracer Dqracer is offline
Houston..we now have the motor mounts..! the motor mount plates are from Hyper Racing, the frame mounts and engine bay will now except any motor that Hyper has plates for. Chain adjustment is a breeze as the motor will slide fore and aft 2". I'll be useing split rear sprockets so gear changes will be a snap also. . The spindles and frt brakes are machined and done too.
I'm liken this head on shot of the kart...
ID:	4521   Click image for larger version
ID:	4522   Click image for larger version
ID:	4524   Click image for larger version
Dqracer
QuickEngineering.net
Old 11-17-2008, 01:23 AM
Bonehead's Avatar
Bonehead Bonehead is offline
I am really looking forward to the Youtube on this one.
Great stuff.
Old 11-17-2008, 09:18 AM
Dqracer's Avatar
BH, you and me both.. wish the guy build'n it would hurry up an' get it done...LOL
Dqracer
Old 12-20-2008, 08:43 PM
Dqracer's Avatar
Man ,, whats takin so long...LOL lets see , wife , kids , work, racin'..etc. etc..
Got the frt disc caliper mnts fab'd up and done, built and polished out the frt wheels (used some old wheel halves and centers,) Now we're workin ' on building the radiators and side pods for the radiators. Custom radiators are EXPENSIVE..! so I opted to build some , started with a salvaged BMW 325 radiator, (free..!) they are aluminum tubed and the tubes are big single ones and are brazed not epoxyed (important) this allows you to make your end tanks and tig everything together. I wanted two 6 x 21 rad's , its easy to cut the original down to size ,I used the top and bottom section of the radiator , start by getting rid of the plastic end tanks, mark your cut so that it falls in the middle of a tube, use a utility knife to cut the fins loose from the tube on one side , then cut thru the header plate on both ends with a cutoff wheel, then take a 36 grit disc and lightly grind the side of the top tube , this will allow you to removed the one side of the tube , buff the edge with a scotch pad and you have a clean look ready for new aluminum tanks (I'll fab those up later) and a top cap for mounting brackets, I just started making patterns for the side pods from cardboard , Those will be made from aluminum also. Back to work...
ID:	4603   Click image for larger version
ID:	4604   Click image for larger version
ID:	4606   Click image for larger version
ID:	4607   Click image for larger version
Dqracer
Old 12-20-2008, 08:57 PM
Dqracer's Avatar
more pics
ID:	4609   Click image for larger version
ID:	4610   Click image for larger version
ID:	4612   Click image for larger version
ID:	4613   Click image for larger version
Dqracer
Old 12-21-2008, 08:31 PM
That is very cool, building your own radiator. I have thought about doing that, especially after having a customer pay big money for two of them, supposedly identical, then not have them fit in the same mount. At least if I'm making them, there is only one direction in which to point the finger!
I may just have to keep that in mind for the super. Ever buy new cores from a radiator manufacturer? I thought you should be able to cut cores parallel to the tubes to resize them, and you just confirmed that. Thanks!
Old 12-23-2008, 07:41 PM
Shmeefer's Avatar
Shmeefer Shmeefer is offline
Building your own custom rads AND putting them in side-pods... badazz!
Old 12-26-2008, 10:01 PM
Dqracer's Avatar
After I decided on a final shape for the pods ( cool word) ,, the next step was cutting out and shapeing a hammer form to create the aluminum panels that will make up the "pods" . I used 3/4 MDF board, (home depot) cut to shape, then sanded the radiused edges with a belt sander, then finished smooth with a palm sander ( do this outside it makes a BFM...! ) To find the correct size of the aluminum needed ,use a thin flexible tape and measure from each side at the bottom , up and over to get the length of surface of the form, this is the actual size piece of material you'll need, I used .060 5052 with a poly vinyl cover on one side, You'll need to cut a top board, cut to the shape of the form only smaller in size back to where the radius around the edges starts, Clamp yer aluminum between these 2 pieces , use a soft faced hammer and strike as close to the top edge of the radius as possible , work your way along until you have a nice smooth bend around all sides. Some areas will require shrinking to achieve the shape you need so work those slowly, I actually made some pie cuts and tig'd the cuts later after shaping, then metal finished the welds and polished the surface. This is one top piece, back to work, I have 3 more to make..
ID:	4624   Click image for larger version
ID:	4625   Click image for larger version
ID:	4627   Click image for larger version
ID:	4628   Click image for larger version
Dqracer
Old 12-26-2008, 10:08 PM
Dqracer's Avatar
Rest of the pics
ID:	4630   Click image for larger version
ID:	4631   Click image for larger version
Dqracer
Old 12-27-2008, 10:25 AM
Ladderbar's Avatar
That's nice. You do have skills,
Old 12-29-2008, 12:06 PM
Very cool! Hammerforms are cool for doing stuff like that, wing ribs, etc.
Something you may want to look into if you have a bead roller is a set of tank rolls. I have a set, and they work very well for doing exactly what you're doing with your sidepods. The only thing about them is you end up having half of the curvature on each piece, rather than all on one side.
The fuel tank in my thread about supermodified headers was done using tank rolls.
Old 12-29-2008, 12:28 PM
Dqracer's Avatar
Graham, yep ,, I wish I had a set of those, the english crafters that built the ole Formula cars made all their tanks like that, and usually gas welded the aluminum seam too. Pretty cool, they were big fans of brazing everything also.
I'm gonna use a step roll die, and put a step along the side panels , so the top and bottoms overlap them, then tig the seam.
Dqracer
Old 01-13-2009, 10:46 PM
Dqracer's Avatar
Found some time to get alittle more done, The side pods are in the final stages of fab work, hopefully I can have them done this weekend, (hopefully)
Tops and bottoms are all hamerformed out, trimmed for fitting of the side panels. I put a 1/16 step flange on both top and bottom edges of the side panels, marked them for the radius bends on the front side openings , then cleco'd everything together to check alignment and fit. So far so good, everybody knows a tight fit means less finish work, this takes some patience and plan ahead about 3 steps...LOL I'm gettin' excited now ,as they take shape. Also ordered up the radiator hose tubes I'll use for the rad end tanks, Aren't they cute..Woolf Aircraft Co. makes these ,, nice stuff at a resonable price.
ID:	4693   Click image for larger version
ID:	4694   Click image for larger version
ID:	4696   Click image for larger version
Dqracer
Old 01-13-2009, 10:54 PM
Dqracer's Avatar
Oh no..! Houston,, we have a problem, I've reached the limit on attachments,, 20.84 MB How do I get more space for attachments..?
still have pics to post. anybody know..?
Dqracer
Old 01-13-2009, 11:06 PM
Dqracer's Avatar
We figured it out,, jus gotta do some house cleaning in the attachment section at Sears..LOL
Here are the rest of the pics.
ID:	4698   Click image for larger version
ID:	4699   Click image for larger version
Dqracer
Old 01-15-2009, 10:14 AM
Very nice work! I get excited when this thread comes up in my email. Based on your work with the radiator, I'm taking the plunge and making one for the super. I just received my core from Howe Racing, and I'm planning things out.
Do you have a link or phone for Woolf Aircraft? The only place I have found aluminum mandrel bends is Burns Stainless at exorbidant cost.
Old 01-15-2009, 10:30 AM
Dqracer's Avatar
Graham, the link is www.woolfaircraft.com
Dqracer
Old 01-25-2009, 05:53 PM
tahoefabrication's Avatar
tahoefabrication tahoefabrication is offline
for aluminum bends try columbia river mandrel i get a lot of stuff from them. Lovin the work, well thought out and executed
Old 01-25-2009, 11:02 PM
Dqracer's Avatar
Thanks for the kind word guys,means alot, well one pod is done and I've started welding up the other side today, its tedious work tig'n these seams to keep the warping and oilcan effect from happening,I don't have a planishing hammer or E wheel to work out any problem areas,,(yet) jus got go slow,start in the middle of the seam,tack it, grind the proud of the weld off, stretch the weld, tack it agin on the other side of center , grind , stretch, tack it agin on the other side of center , grind stretch,, then fill in the gaps doin' the same steps, ,PATIENCE..! I keep tell'n myself...LOL they finished sanded out pretty nice fer a farm kid.. the second pod is goin alittle faster now that I've got a zipper on the routine. Whatda ya think ,, should I polish them out , or jus powder coat them..?
Columbia River Mandrel has some nice stuff, actually I looked for what I needed there first , but they didn't have 1" dia, the smallest they had was 1.25 dia.
ID:	4743   Click image for larger version
ID:	4744   Click image for larger version
ID:	4746   Click image for larger version
Dqracer
