Old 02-10-2016, 02:32 PM
idickers's Avatar
idickers idickers is offline
Removable Door Bars
Does anyone have experience with making a cage for a track car with removable door bars? I'm building a cage for my track car, using 1.5" x .095 DOM. This is for track days not racing, so I don't have to worry about rules, but I'm using SCCA racing as a guide for tubing and mounting points. I'd like to make the door bars removable, and am deciding between sleeving the connections with a larger piece of tube, or using weld in clamps like this: http://www.tmrcustoms.com/store/inde...oducts_id=2080 Any experience with these types of clamps?
Old 02-10-2016, 03:06 PM
I think those would be fine. Actually, they should improve stiffness over a typical NHRA legal door bar, like this:
http://www.appliedracing.com/roll-ba...vis-mount.html
Because the two halves are keyed together and held with two bolts.
The only concern I would have is the sharp square corners that will be exposed when you have the door bar out. Depending on the placement, they could literally be a real pain.
Old 02-11-2016, 04:33 PM
idickers's Avatar
Thanks for the thoughts, I may go with these.
Old 02-11-2016, 05:27 PM
So would it be bolt in or pin in? I have seen some where the lower front is a pivot/hinge and the top rear has a spring pin so you can open the car door, then unpin and swing out the door bar for entry/exit. Are you going to just hop over it when it's installed and take it out for when you're hooning around town?
Old 02-11-2016, 06:02 PM
idickers's Avatar
I envision using two sets of clamps, one towards each end of the bar, so that the majority of the bar can be removed for proper hooning, but I would leave it installed and padded for track sessions.
Old 03-29-2016, 09:19 AM
KarolisMak's Avatar
KarolisMak KarolisMak is offline
Is there another way to track sessions???
Old 03-29-2016, 09:29 AM
idickers's Avatar
You can get on track by attending lapping days with many organizations from car clubs to track day specialists, or you can race with any of the organizations such as SCCA, NASA or marque-specific racing like BMW Club or Porsche Club. The lapping days don't require a cage, but I've done it often enough in an old enough car that I decided that I felt safer going with at least a roll bar and a proper harness, and what the heck, why not stiffen the frame up with the cage "while you are in there"?
