Go Back OFN Forums > Marketplace > Classifieds
Classifieds Got a tool you don't use? Want to swap tools with another user? Need a tool?
Old 09-16-2013, 06:41 PM
zimsport's Avatar
zimsport zimsport is offline
496 internally balanced rotating assembly
Ive got a complete Eagle gen v 496 rotating assemble. Its internally balanced. The parts have never been run. Was built by a shop and installed in a boat, then sat for 10 years. Condensation got into cylinders through open exhaust valves, creating cylinder rust. Customer brought motor to me to freshen up, and after finding the rust, and needing a new block, customer went with a bigger motor. All the parts are good, but have some surface rust. None of the machined areas are rusty. I would pull rods and pistons apart and clean, then reinstall with new rings and bearings. It is an all Eagle 4340 kit. Internally balanced, h beam rods, and srp pistons. It was originally for a pro-charged 496 boat. I can send pics if asked.
Asking $1500
Check out some of my work...
http://www.facebook.com/profile.php?...03095253108640
