Old 11-24-2012, 05:09 PM
Peter H's Avatar
Peter H Peter H is offline
Hi steer ready for welding.
I still need to remove the washer at the shock mount!! I keep forgetting it..... must be Alzheimer....
Old 11-25-2012, 04:32 PM
Peter H's Avatar
Today Hi steer welded together. Seems to work perfect. Next week take it back apart for paint. Another chapter closed!! :-)
Old 11-26-2012, 11:02 PM
KyTrash's Avatar
KyTrash KyTrash is offline
nice work.
Old 12-23-2012, 12:42 PM
Peter H's Avatar
Steering is aligned, brakes bleeded, cooling water added,.... it's getting close...
Last week i had a answer of the driveshaft builder.
He can build what i want and the price is OK.
Order will follow 1st week of January!!!
Old 12-24-2012, 10:37 AM
Peter H's Avatar
Old 01-06-2013, 08:18 PM
Peter H's Avatar
Little update:
Old 01-07-2013, 12:02 AM
Trevinator's Avatar
Looks Awesome!!!
Old 01-07-2013, 11:24 AM
Originally Posted by Peter H View Post
Likely I can not see what I am talking about so if I am wrong...
In the above it appears that you have a SRE attached to a Ball-Joint stud in the Pitman arm that has been shimmed with a stack of washers.
In essence a pivot on a pivot. I'm guessing that the stack of washers between the arm and the and the SRE are there to prevent motion of the ball-joint and/or space the SRE down on the taper to allow the nut to tighten and further that there is a tapered section inside the SRE Pivot ball.
Frankly speaking this while it may be functional at the moment, is a failure waiting to happen!
I recommend that you revise the joint, The simplest way would be to machine up a Solid Rod End or find one and then machine the taper for the Ball-Joint stud and attach it that way.
I will also recommend that you replace the "Short-Stacks" of washers under all the other SRE's with the correct misalignment spacers and then a single safety washer on the top spacer.
Old 01-07-2013, 01:19 PM
Peter H's Avatar
It seems like this, but it isn't....
I have a machined spacer inside the SRE with a taper hole to fit the ball joint stud. No movement possible.
Old 01-07-2013, 01:21 PM
Cool!
Old 02-08-2013, 06:57 AM
Peter H's Avatar
Drive shaft adapters are ready!
Old 02-08-2013, 02:34 PM
fabdaddy55's Avatar
fabdaddy55 fabdaddy55 is offline
WOW! all I can say is wow!
For a first build you men should be very proud indeed.
How long before you can drivel drive it?
Cant wait for THAT video.
Old 02-09-2013, 04:50 PM
Peter H's Avatar
Thank you...
Maiden run probably a few weeks. Now I have the adapters, I can measure the exact length of the drive shafts to order them. They will be custom build by a specialized company (GKN driveshafts).
Old 04-10-2013, 01:44 PM
Peter H's Avatar
The postman made me very happy today!!!!
Old 04-13-2013, 03:59 PM
Peter H's Avatar
It moves!!!!
Old 05-05-2013, 08:16 PM
Peter H's Avatar
Movies:
http://youtu.be/r9fpmDbgh0s
http://youtu.be/s0RbzpTyMm0
http://youtu.be/FvbgO6V895c
Old 10-02-2013, 08:44 PM
Peter H's Avatar
It has been a while, so a little update.
This summer we did several testdrives and joined some local offroad club meetings.
In general i'm very happy with the build.
The V6 engine is awsome. Lots of power, lots of revs, plenty of torque. Everything is running nice and keeps cool, even in hot summer conditions.
The 4-link we build is OK. Lots of flex, nothing rubs...
There is only 1 issue, but a serious one....
Axleshafts break like they are made from chocolate...
After 30 minutes the first axleshaft broke (rear right).
So i upgraded the diffs from 29 spline to 31 spline.
The 31 spline shafts did hold up about 60 minutes... then both rear were broken.
The current Nissan Patrol 160 axles are to weak for the V6 engine!
Currently I'm looking for Nissan Patrol Y61 axles. People keep telling me they are very strong (equal Dana 60?).
Any thoughts? Other possibilities?
Old 10-03-2013, 06:11 AM
Hello Peter,sorry your having axle probs but was bound to happen i'm afraid,the c200(16)'s your using are a good axle but small, just not strong enough for your use,I'm a patrol axle fan and have a collection!!Yes the H233 from Y61 is STRONG,easy beating a std Dana 60 IMO,euro models come with rear locker as std and a terrano 31spline 233 rear LSD will fit front 233 from Y61
Y60 233's are physically similar but front CV's,brakes are smaller
You will not break a set of H233's from a Y61 on your truck but you will loose clearance and gain a lot of weight and width(approx 100mm wider than 260,not sure about 160 c200 width) the model designation used is the metric diameter of Crown gear,
When searching for axles note that for a period (00/01)some 3.0 diesels were fitted with H260's-looks similar but this is way too big for your truck.
I have all types and can measure and photo for you anytime if you need.These guys use mostly standard running gear
https://www.youtube.com/watch?v=Ek0Zf64NVso
Old 10-06-2013, 07:39 PM
Peter H's Avatar
Thanks for the info. Great video!
I haven't decided yet. I can buy a complete set of Y60 axles with brakes, springs and trailing arms for 350. A set of Y61 axles will cost me between 800 and 1000 without the mounting hardware. For this difference I can buy a lot of CV joints....
Have you any idea of the weight difference between Y60 and Y61 axles?
Old 10-07-2013, 05:01 AM
Very little difference in weight between 60 and 61,rear almost identical but front will be a little heavier because of larger brakes and CV.
Trailing arms are probably no use to you anyway,very light and short for offroad and front radius arm's are way too stiff..i dont think you can buy many Good CV'S for 400e really and 61 CV wont fit 60 axle (breakdown in event is also emotionally very expensive)
+you might want to fit bigger,wider tyres in future
+more chance brakes will be in good condition on 61 axles
both options are very cheap in reality,a diff lock alone for any other axle will be 800e
Can you buy 60 rear and 61 front?cheaper?
Ratio's Approx
2.8D = 4.625
4.2D = 4.1
3.0D = 4.3
