Old 10-07-2013, 01:26 PM
Peter H's Avatar
Peter H Peter H is offline
Maximum tyre size will be 35".
Difficult choice....
Old 02-16-2014, 08:19 AM
Peter H's Avatar
This afternoon, I'm going after a set of Y60 axles. Complete with locker in the rear, 4.625 gears, wheels and tires (Silverstone MT-117 extreme, +/- 35" in good condition) and a set of coil springs, all together for 500!!! I'm a happy man! The work can continue!
Old 02-16-2014, 10:06 AM
Good deal Peter
Your original front outer housings should fit Y60 front
Old 02-18-2014, 01:31 PM
Peter H's Avatar
???? C200 housing is completely different...????
Old 02-18-2014, 02:43 PM
The "knuckle" on 200 and Y60 will swap over so you can keep/use all your high steer mods plus the Y60 track rod is totally different and at the rear anyway
Old 02-18-2014, 04:05 PM
Peter H's Avatar
Went shopping!!!
That's really good news! My steering system worked great. It would be a shame to lose it...
Old 02-18-2014, 04:33 PM
Congrats..some real axleslook very clean and tidy
Old 02-18-2014, 07:47 PM
Peter H's Avatar
Yep, previous owner did all the cleaning.
Axles were used on a bobtailed Range rover trophy car project which never finished and is now sold in pieces...
Lucky me!!
Old 02-19-2014, 01:01 PM
Peter H's Avatar
Can i swap the manual freewheel hubs of the C200 with the automatic ones in the Y60 axles? Peoples keep telling me the automatic freewheel hubs are a P.I.T.A...
Old 02-19-2014, 02:01 PM
I Never had any problems with auto hubs,they are much stronger than your original manual and no they cannot be swapped without mods..leave them alone,no grease and dont mix up sides,they also have a manual setting which locks them permanently...auto mode wont ever unlock if you have LSD or rigid diff of any kind fitted
Old 02-20-2014, 01:28 PM
Peter H's Avatar
leave them alone
OK, that's easy. Thanks.
Old 02-20-2014, 01:38 PM
Terrano rear LSD will fit front,must be banjo type axle,pressed casing same diff size as y60 but 31 spline
Old 02-20-2014, 04:18 PM
Peter H's Avatar
Great tip, thanks!
Old 03-16-2014, 04:41 PM
Peter H's Avatar
Sun was shining today, so i started working again...
Broken rear axle ready to dump!
Old 03-16-2014, 05:11 PM
Hey why on earth have you stripped the axle Peter???
Old 03-16-2014, 05:34 PM
Peter H's Avatar
4 Link mounts needs to be welded on the axle housing, and a empty housing is easier to handle. Axle gets new bearings and new oil seals anyway...
Tomorrow i will open the old C200 axle to examine the damage of the drive shafts.
Old 03-16-2014, 07:28 PM
ok but Welding is no problem on complete axle(and factory mounts are Perfect for 5 link!!but already modified???)...replace bearings and seals????something wrong if you need new bearings and seals on this axle,IMHO just save yourself time money and grief and just refit original
Old 03-16-2014, 08:15 PM
Peter H's Avatar
Axle was already modified. A 3 link Landrover system was fitted.
Not my cup of tea :) and the welding wasn't that great....
Old 03-31-2014, 04:14 PM
Peter H's Avatar
Ready for assembly (when the paint dried....)
Patrol R160 (C200) vs. Patrol GR (Y60)
Old 04-01-2014, 06:58 AM
Well may not look purdy but i'm sure its pretty strong!!!
