Old 06-19-2017, 05:27 PM
Gate hinge, self closing.
Looking for ideas... or weld on solutions.
I have to get a few gates built.
Nothing fancy, just walk through gates to keep the Deer out of the flowers.
The tricky bit is on two of them I need to have a self closing tendency.
The mechanism must blend into the gate frame work (1"-square stock) and must work both directions, the gate will swing in OR out (180).
These gates are outdoors and will see 100F summers and -30F Winters.
Anything?
Old 06-19-2017, 06:08 PM
Self closing gate hinges like this one use a ramp so the gate lifts up slightly as it opens and gravity trying to pull it back down puts it back to center. You can do something similar by angling the post toward the direction you want the gate to close and compensating for the angle in your framework, but these hinges have adjustment.
Old 06-19-2017, 06:15 PM
I'll look closer at the hinge.
Skewing the hinge axis only works in one direction these gates will open both directions.
Old 06-19-2017, 06:36 PM
If you tilt the top of the post toward the closure direction, it will work in both directions.
Old 06-19-2017, 06:56 PM
Yes but how do I tip it to close both directions?
Old 06-19-2017, 07:28 PM
Imagine two posts, one on each side of the gate. One is the latch post and the other is the hinge post. If you take the top of the hinge post and tilt it toward the latch post, by gravity the gate will always try to swing toward the latch post, regardless of whether it's opened inward or outward.
The dimensions and weight of the gate along with the angle of the hinge axis will determine how difficult it is to open and how strongly it tends to close itself.
Old 06-19-2017, 08:13 PM
ok got ya... must be the heat
Old 06-19-2017, 08:19 PM
My guess unless it really latches/lock the deer will still get in and eat the Daisies. They pretty crafty but taste like crap.
Old 06-19-2017, 08:51 PM
I proposed eliminating the Flowers...
Having quit eating Red Meat completely a few years back; I just let them have the back 10 and we get to watch the Fawns develop year after year.
& no we do not feed or water the Deer.
Old 06-19-2017, 10:04 PM
Ok. a simple solenoid latch that would engage after dark using a photo-electric cell. You could also use a 110V timer to lock and unlock automatically. Simple really just some wires, springs and such. "Bolts right up."
Old 06-20-2017, 12:42 AM
That would do nicely but make it 12VDC and solar
Old 06-20-2017, 09:38 AM
Me thinks you are going to want this kind.
Old 06-20-2017, 10:40 AM
I don't think anyone has mentioned the saloon bar swinging door hinge style yet. I believe it's like two spring loaded hinges in one package, needing two packages per door.
Old 06-20-2017, 11:00 AM
Way out of the budget.
Way cool solution!
Old 06-20-2017, 11:05 AM
...exactly what I was thinking originally, but I never found them for outdoor application.
The hinges will be over the top step up, to the deck, and I can't have them rust and stain the decking over time.
Old 06-20-2017, 03:03 PM
Just fabricate a set using stainless. Springs, well um. Use surgical tubing with a black sheath over it like the stupid expanding hoses.
Old 06-20-2017, 04:06 PM
...time I spend on this, is directly slowing the rebuild of my 75...
It is kind of like Beer, the time I'd spend brewing could be spent drinking
Old 06-20-2017, 04:33 PM
https://www.hingeoutlet.com/collecti...blsprh-us32d-6
https://www.deelat.com/building-mate...ish-15mm-thick
Old 06-20-2017, 05:46 PM
Thankz! Price isn't bad too
Old 06-20-2017, 05:56 PM
Gravity is cheap, simple, and reliable. Just sayin'.
