Old 05-31-2017, 09:21 AM
wedged's Avatar
wedged wedged is offline
and now we are caught up...
Old 05-31-2017, 12:48 PM
Nice update and thank you for it!
Old 05-31-2017, 02:06 PM
Originally Posted by wedged View Post
That is cool as hell!
Great work man. This is going to be awesome.
Old 05-31-2017, 07:55 PM
wedged's Avatar
forgot this one. for ground wires, i drilled holes in the frame and put a 5/16" flange nut upside down into the hole and welded it in place. I did that in 3 spots. Battery is grounded to the frame, cab to the frame and engine to the frame.
Old 05-31-2017, 07:56 PM
wedged's Avatar
thanks. i couldn't bring myself to cut the dash or use billet insert gauge mounts that are available.
Old 06-10-2017, 10:29 AM
wedged's Avatar
there is still a lot more to be done...
click for video
Old 06-10-2017, 07:28 PM
Linkynoworkey
Old 06-10-2017, 08:13 PM
wedged's Avatar
Fixed
Old 06-10-2017, 09:00 PM
Baddass!
Old 06-11-2017, 01:42 AM
totally dig the look and sound
Old 06-12-2017, 04:33 PM
Sounds great Any issues the first time out?
Old 06-12-2017, 10:08 PM
wedged's Avatar
Aside from having no glass, all body bolts and rear suspension bolts loose, no gauges except oil pressure, wires hanging everywhere under the dash, front end alignment way off and more, it was perfect !
Old 06-18-2017, 06:29 PM
wedged's Avatar
did some wiring for the lights and started working on the gauges
Old 06-21-2017, 04:52 PM
Are those "high beams" up by the door? Cool stuff. Did you take off the white lettering on that lens or is it just missing in the last photo?
Old 06-21-2017, 07:37 PM
wedged's Avatar
No, originally the cowl lights were just markers. I converted them to marker/signal lights. The lettering on the gauge glass must have been water based because it came right off when I cleaned the glass. I've redone the lettering with a paint pen. The lettering is recessed so the paint just flows into the recesses, then scrape off the excess when it dries.
Old 07-05-2017, 07:45 PM
wedged's Avatar
the glass showed up today. back window and side windows are tinted. The windshields are clear.
Old 07-09-2017, 05:10 PM
wedged's Avatar
installed the gauges. I need to ground the gauge lights and add some hidden indicator lights for the turn signals and high beams. Also have to measure for a speedo cable. I have the fuel surge tank out to fix a few small pinholes so i could not test the temp gauge. I had the oil pressure gauge hooked up temporarily before. The volt gauge and fuel level worked fine.
Old 07-16-2017, 05:40 PM
wedged's Avatar
installed the hood, mounted the running boards and started prepping the windshield frame for repair of the swiss cheese rust holes.
Old 07-18-2017, 05:35 AM
oh my word, what a handsome machine. jolly well done old chap. bloody excellent.
Old 07-21-2017, 01:48 PM
unsinkable's Avatar
unsinkable unsinkable is offline
Great build, good thread, good brakes, good tires, but the excellence is in the wheel widening. Me likes!
