Old 10-27-2017, 01:51 AM
A-To-B Motorsports's Avatar
A-To-B Motorsports A-To-B Motorsports is offline
Toyota race truck
Ive searched amd searched and cannot find alot of info on front suspension upgrades for a 84 2wd toyota pickup, we are going to build a full on drag racing truck. Now a big block chevy is alot heavier than a stock 22re i need help or pointed in the correct direction to beef up my stock front suspension before i go and try and fabricate some heady duty control arms so someone help
Old 10-27-2017, 01:10 PM
For a drag race application, all you really need is the correct springs for the weight and properly set up shocks. I would look at simply replacing the springs and shocks with a short travel Coil-over (made for Drag Racing).
Depending on how much weight you need to lose I might switch to a R&P unit, in place of the Yota linkage and gear box.
Iíve used this company in the past for similar builds and they are a one stop shopping experience.
Old 10-27-2017, 07:20 PM
Its torsion bar front suspension so can i just replace the shock with a small coilover to help with it or will that not work since the torsion bar connects to the upper control arm?
Old 10-27-2017, 07:40 PM
Going to have to go refresh my memory on the Toy susp.
How fast do you think you will be running?
Old 10-27-2017, 08:52 PM
Really really fast... were putting a twin turbo big block chevy v8
Old 10-28-2017, 01:21 AM
...in that case you need a new chassis and suspension.
You can get rid of all the Toyota stuff.
Old 10-28-2017, 01:36 AM
Thats the plan... the rear is going to be completely chopped and new back frame fabricated to fit a shortened 4 link 9inch drag racing axle im trying to just see or find pictures or build threads on who has done drag racing suspension on a toyota front suspension, what aftermarket or home fabricated arms what shocks and or coilovers balljoints spindles etc
Old 10-29-2017, 09:43 PM
You'll be time and money ahead to just buy a frame set up for what you want to do. Seriously!!
