Go Back OFN Forums > Shop and Tool Talk > Torches and Torch
Torches and Torch Plasma? Oxy? Which one? How do you use them?
Old 11-17-2016, 10:48 AM
Home Fab weird size plasma table
Ok. I know I am crazy but I think there is logic behind my madness.
The rules:
Smaller shop without a lot of extra room.
No real way to handle sheets of metal. Even the thin stuff can be more than a handful to store and move around. I do have a 16ga shear.
Do a fair amount of fab work but its not how I make money.
Typically smaller parts.
So I WANT a 12" x 48" plasma table. Sit next to the wall out of the way. I can then use flat bar and easily be able to handle the material with out a crane or forklift.
Maybe even 12" x 24". Yep crazy talk.
Really how big do you need at home?
How big are the parts you actually cut at home and how many?
Its a whole bunch easier to store flat bar in misc sizes that sheets, well in my shop anyway.
Opinions? You can't tell me I'm wrong cuz this is America and we all have an right to be different.
Old 11-17-2016, 03:08 PM
When I was considering a table I estimate that 95% of my parts could be done on a 2'x2'.
However, I came to the conclusion that 25 by 50 (Travel) would be the right size.
I came to this size because 24" was a good size to have the steel vendor shear to and 25" travel lets me cut that and the 50 because I can cut a full 48" long (again shear size) and depending on the shape up to 55" long.
You are not the only crazy one
I finally got smart and decided that I could easily farm-out my small volume and have a cleaner shop at the same time. AND thus, the best size is whatever someone else had!
Old 11-17-2016, 04:43 PM
Yes, if you want to bring in payback I should just be getting everything waterjet cut from my vendor I use for a few parts. I guess it comes down to turn around time. That's why I cut stuff on my mill that really should be plasma cut. I WANT IT NOW!!!
Old 11-17-2016, 05:02 PM
Originally Posted by R.DesJardin View Post
I WANT IT NOW!!!
That is why I have a torch and full tanks
Old 11-17-2016, 07:03 PM
What every works for you the size of the table can be changed any time .
It is the Plasma machine and the CNC goodies that matter
The ones I work on tend to be just a tad bigger just depends what your cutting
Old 11-18-2016, 10:18 AM
Yes you need a good machine and robust table design as that's the secret to cut quality and accuracy. And the price doesn't change much as size goes down since you still need all the same cut, control and movement components. If I had a good big plasma then I could build a good small plasma. Dang.
Old 11-21-2016, 02:00 PM
I think Plasma tables end up like crawlers and everything else built these days. If you don't have a 1500 hp twin turbo your ride will suck, it's just not true.
I want a 24" x 48" capacity table, so very similar to E's ideal table.
If once I acquire this table and it is constantly too small or the potential is there to make it financially worth while to have a larger table I will use the small table to build the parts needed for the larger table.
I will also likely build a chain drive table with skate bearings. All the bling is just not needed in my opinion.
Old 11-21-2016, 10:15 PM
Well said!
Old 12-14-2016, 12:10 AM
MQUnlimited's Avatar
MQUnlimited MQUnlimited is offline
I say go as big as your wallet will let you. Too many times we've seen or done ourselves buy what ever it maybe, to just enough for the time being and quickly our grow it. I'm in the market for a plasma table at the moment, prefer a 8'X4' but I have limited space because my chassis table is 16'X5' in a 2 1/2 car garage! So 4'x4' is what I have to settle with.
Old 10-20-2017, 01:04 PM
So I am back looking at tables as I just bought a new place with a bigger shop. I just got a quote for a 4x4 4400 table from Torchmate, with a Lincoln plasma and ready to go, $20K. Yikes, I was shocked. JD2 and Star Labs have decent machines for around $10K without the plasma machine. But I still want a smaller machine, 2x4 or 2x6, crap even 1x6 would be sweet. I don't want to have to handle full sheets of 3/16" or 1/4" plate. Let me buy flat bar and cut my tabs, brackets and trusses from it. The home hobby guy has been left behind by everybody. Now what to do? what to do!
Old 10-20-2017, 01:29 PM
Have you looked at ArcLight Dynamics? Their packages seem a little more reasonably priced than Torchmate because a ton of stuff is standard on them that is optional on Torchmate.
And they're pretty local to you (Oregon). Part of their deal is each table comes with 1/2 day of factory training at their facility. They are at the top of my list when the day comes that I can buy a plasma table.
Old 10-20-2017, 02:31 PM
Not sure why I didn't list them but, Yes they are at the top of my list also, Bend, OR is ~4hrs from me so not to bad to drive to for picking up the machine and the training.
Old 10-20-2017, 04:09 PM
Agreed with Arc Light at-least by reputation.
I also found this:
http://gotorch.com/index.html
Old 10-20-2017, 04:13 PM
Arclight would be my choice also.
Are against building the whole thing yourself?
The guy that came up with the plasma tube notcher that BT now sells is in Oregon, JGS FAb or JGS turbo. He is very sharp with all the electronics for a DIY guy. He knows how to keep it low cost but high performance.He might be able you walk you through it.
I like the small table idea.
Do you do Instagram?
This is one of his sites, I think its pretty dead, but you get the idea. I can contact him if your want.
http://www.google.com/url?sa=t&rct=j...tw88qcukg-vO2A
Old 10-20-2017, 09:50 PM
I know who JGS by reputation for his amazing builds. I am not ready to pull the trigger yet, just bought a Diversion 180 this week and a 252 earlier this year. Need a few more high priority tools first. I was just starting my research to figure out what direction to go. I really don't want to build one. Seems ironic since I have welders and CNC mills in my shop right!
I am only on Instagram through my business RADesigns Products.
Old 10-20-2017, 10:47 PM
OK Cool.
Are you near Coos bay?
I'll check out your Instagram.
There seems to be a few RADesigns? Skater stuff?
Mine is 525_Industries
Old 10-21-2017, 09:20 AM
OK Cool.
Clarkston, WA, nowhere near Coos Bay, think Idaho, Oregon, Washington corner.
RADesigns Products, I make shifters, transmission and t-case
Old 10-21-2017, 10:00 AM
LOL, I was close! HA!
Old 01-06-2018, 07:05 PM
kkroger's Avatar
kkroger kkroger is offline
I know I know OLD thread... When I built my plasma table I landed on 5x5 because it was the absolute largest machine I could fit in my two car 22x22 garage.... Largest sheet I could reliably handle by myself... OK I never intended it to become an occupation but since I do Exceptional work it has become my profession... in an 8000 Square foot shop now, with another 5x10 table and a Powder coating operation and products that I make for another manufacturer... I paid for the outlay on the table in 6 months, I bought the Star Labs table outright 2 years later, Powder coat oven is bought and paid for, the powder application is paid for and average gross income per month is about 150k... "Actual results may vary" granted I knew CAD and CAM prior to the table, I have a CNC Mill and a Lathe on the floor too, Welders etc etc etc... It is a good gig if you can get it...
Old 01-06-2018, 07:28 PM
Originally Posted by kkroger View Post
I know I know OLD thread... It is a good gig if you can get it...
I hear that a lot, but for what I do I don't want to invest in material handling for the sheets. And if someday I get my weird size and if someday I get too big and need a 5x10, then how nice would it be to have the mini in to corner to to weird ne offs without having to load a sheet. My CNC mills are what make me money and I focus on that business. But who knows.........
