Old 11-08-2017, 06:29 PM
eatSleepWoof's Avatar
eatSleepWoof eatSleepWoof is offline
Hobbyist bender for thick, but narrow metal?
Need some advice.
I'm in a condo with very limited space. Can't throw in a huge, industrial bender (don't need one, either).
I have an ongoing need to make various metal brackets for my truck. The thickest, most heavy-duty stuff I've needed so far was bending a 3.5"-wide piece of guage 10, 304 stainless steel to a 90-degree angle.
The majority of the work involves thinner, narrower, softer metals. Things like 1/8"-thick aluminum in 1" or 2" widths, or steel in the same dimensions.
Is there a tool out there that will allow me to do this at home?
Old 11-08-2017, 06:39 PM
If you a press or room for a press, you might consider a press brake that fits into one or a bench-style press brake. Something like these:
Or if you are bending close enough to an edge where you don't need the material to feed through (or if it isn't too hard to bend and can hang "outside" of the vise), you might try a vise brake like this.
Old 11-08-2017, 06:43 PM
Thanks, Clint.
Could you give me a make/model number for the first tool? Or anything I can plug in to Google to do some research. // edit - looks like "Press Break" turns up those styles of machines. They're a bit too large I'm afraid...
I actually already have a 6" vise brake, identical to your second photo. Unfortunately I've found that it doesn't work too well. On numerous attempts to bend 1/8"-thick, 2" wide steel, I reached points where I was bending the vise's handle instead of the metal. I was also using a 3"-long DOM-tubing pipe on the vise handle for additional leverage.
Old 11-08-2017, 06:47 PM
What about something like these options?
1. https://www.kakaindustrial.ca/produc...shears-machine
2. https://www.kakaindustrial.ca/produc...shear-and-roll
The specs for both state that they can only bend metal up to 0.04" thick, whereas I'm aiming for 0.125". Then again, their specs are likely for material that is the full 8" width, and I'd be working with 2" width max. Would these tools be able to bend thicker material if it's at smaller widths?
Old 11-08-2017, 06:53 PM
Also found this: https://www.amazon.com/KAKA-Industri...0H1ZXCY8B70WJ2
Any thoughts on the machine?
Old 11-08-2017, 06:55 PM
I searched for "benchtop press brake" and that one came up. It is carried by Trick Tools. The price seems a little high for what it is. You could probably find other versions out there or make your own.
http://www.trick-tools.com/Bend_Pres...on_BP1020_1618
Old 11-08-2017, 06:59 PM
I like that kind of bender too. They make version of that with replaceable tools so you can do scrolls and other decorative work.
Old 11-08-2017, 07:07 PM
Thanks for the feedback.
That KAKA UB-100 is appealing. And for the first time ever, it's something that is actually cheaper in Canada than on Amazon US.
The specs describe it as:
HIGH CAPACITY OF HOT BENDING AND COLD BENDING. In term of hot bending, it can bend flat steel 3.93x0.59", round steel 0.86", square steel 0.86x0.86, angel steel 3.93x0.47. In lieu of cold bending, it can bend flat steel 3.93x0.2, round steel 0.71, square steel 0.63x0.63 and angel steel 2.36x0.31"
How does bending stainless steel compare to bending mild steel? Do you think this tool would be able to bend a 1" wide, 10gauge piece of 304 stainless steel to a 90-degree angle?
Old 11-08-2017, 07:44 PM
If you like that machine, be sure to look at the other variants offered by manufacturers. Sometimes tooling is cheaper for one or another or the capacity or capabilities vary. I think that is often referred to as an "ornamental bender", "universal bender", "scroll bender" or "flat bar bender". I don't personally own one and only have seen them in friend's shops. Maybe someone else will chime in with more experience.
Stainless is generally more difficult to bend than mild steel of the same dimensions.
Here are some others you might want to look at:
https://www.amazon.com/Universal-Scr...o_sbs_469_t_2?
https://www.amazon.com/UNIVERSAL-BEN...S7HA5CGE5S7EWV
https://www.baileigh.com/index.php/u...oaAlT7EALw_wcB
http://www.ebay.com/bhp/universal-bender
Old 11-08-2017, 10:08 PM
Scrambled's Avatar
Look up compact bender. I have one and bend all types of stuff with it. You can do 90 degree bends or bends with different radius. I think mine came with 6 dies. I paid 99.00 and made a cheep stand.
I also made a larger attachment where I can bend 2.25 cap rail for handrail.
Steve.
Old 11-08-2017, 10:20 PM
Bailiegh sells one like the KAKA also.
Old 11-09-2017, 10:34 PM
Thanks for the tips, guys. That's enough to point me in the right direction!
Old 11-10-2017, 06:25 PM
I think you should consider the Swag Press Brakes and an economy bottle jack press.
Old 01-01-2018, 04:08 PM
I know this is probably too late to be useful, but have you looked at a Hossfeld bender? I just posted another thread about what I've been able to do with mine, sounds like you're doing similar things.
