Old 09-15-2009, 01:53 AM
Chairmnofthboard's Avatar
Chairmnofthboard Chairmnofthboard is offline
Originally Posted by jmastersinc View Post
I am pretty sure it is
Can you measure the your stock rear end and the 9". I want to use the same rear end, but I'm afraid that it might be to narrow.
Old 09-15-2009, 09:29 AM
jmastersinc's Avatar
i don't have a stock rear end, but I have already had this one under my car with tires and it fits perfect, i did some research and they are the same width here is a chart of all 9 inches;
http://www.jalopyjournal.com/forum/s...d.php?t=302774
it says the versatilea is 58" and the stock rear for the 63 belair is 60 but when it is in it sure doesn't seem shorter
Old 09-18-2009, 09:43 PM
got a parts car
Old 09-18-2009, 09:44 PM
its a 64 impala 4 door all i wanted was the rear end but he made me take it all, lol oh well tons of good parts
Old 01-13-2010, 12:43 AM
Got the rear end in, (went with a stocker for now 9" later) and have the engine bay ready for the 350 and 4 speed.
Before
After
Old 01-13-2010, 12:44 AM
Hoping to get the motor and trans in this weekend so I can make the cross member, ther is not a current cross member so I am going to build one out of tube and a couple of poly bushings.
Old 01-13-2010, 12:51 AM
I was wondering what happened with this. Any pics of how you did the rearend?
Engine bay looks a lot better. Did you strip down the rust before painting?
Old 01-13-2010, 01:14 AM
I just threw in a stock rear end from this 64 Impala I traded a trailer for (than traded the Impala for a radiator and motor mounts, made a deal with the first guy that I would NOT scrap it, made the same deal with the second guy not enough of these around to be scraping them out).
Old 01-16-2010, 05:46 PM
Got the motor and 4 speed in today, hoping to get the cross member built tomorrow than start on the clutch linkage and peddal assembly, don't have anything to go off from so it is looking like trial and error time.
Old 01-25-2010, 10:01 PM
Picked up the exhaust today, and who know that a one peice impala exhaust system with headers wouldn't fit in a 99 suburban? But we got er home also picked up a drive shaft too got both for 100 not bad i think;
Old 01-27-2010, 02:08 PM
Old 05-23-2010, 10:59 PM
got it started a few days ago;
Old 05-23-2010, 11:01 PM
and started on the inside getting the shifter in for the muncy 4 speed and servaying the cancer;
And the holy floor;
Old 05-23-2010, 11:02 PM
I am deciding if I should go ahead and order new pans or try my hand at fabing up some from scratch, never done it before
Old 05-26-2010, 11:14 AM
Blind Studios's Avatar
It's got to be cheaper to order new ones, right????
Looks like lots of complex shapes to that floor board.
But, I can't say that I've done alot of sheet metal replacement. All the sheet metal on my project is flat.
Good Luck
Keep up the good work!!
-Jeff
Old 05-26-2010, 11:51 AM
Congrats on getting the motor fired up!
Are aftermarket patch panels available for that year/model? Personally I would buy them rather than make them from scratch, but I guess that depends on your plans for the car.
Old 05-26-2010, 04:24 PM
the pans are about 300 bucks, or I was going to do a basic best I can, out of sheet metal
Old 06-14-2010, 03:00 AM
Finially found a clutch pedal and linkage, picked up the pedals, linkage, throttle pedal linkage, and a manual trannie speedometer for 35 bucks;
Old 06-14-2010, 10:37 AM
streetwerkz's Avatar
Wish I would have caught you needed a factory rear end, I have the one out of my 64 Impala SS that needs a good home.
Also have all the factory suspension parts front and back in good shape, and powder coated gloss black for a smokin deal if you have a need
Old 06-14-2010, 11:18 AM
I am thinking about rebuilding my frount suspension, hows the ball joints and bushings in you a-arms, also is it disk or drum?
