Old 03-07-2016, 06:15 PM
Gotlift's Avatar
Gotlift Gotlift is offline
F-250 Prerunner Bumper
Definitely learned a few things on this build. I should have put the mounting brackets 1"-1.5" further away from the bumper. I cut them a little short, which changed my bend points on the main bar. I intended to lay the bar on and then mark my bend points on the outside of the mounts, but they were too close to the bumper and I didn't have a straight shot between the mounts. I then had to bend the bar on the inside of the brackets to make it fit. It didn't necessarily change the look much, but I would do that different next time. I still need to gusset the mounts.
All in all, I think it turned out okay. I just need to mount some lights. I'll most likely sell this one and turn out another one.
Old 03-11-2016, 05:28 PM
dkr_diego's Avatar
Nice Job!!!
Old 03-11-2016, 10:19 PM
310kick's Avatar
310kick 310kick is offline
Looks clean and you didn't have to drill your bumper.
