Old 11-07-2007, 07:05 AM
jhulsey's Avatar
jhulsey jhulsey is offline
How much lift
I am ordering a set of custom springs from alcan for my cj-5. I will be running SOA, full width chevy 1 tons. As it stands I have they set at 1.5" of lift. How much lift do you think would be required to fit 40" tires. I know the body will have to be cut or beavertailed. Any help would be greatly apperciated.
Old 11-07-2007, 10:19 AM
$CEEP's Avatar
$CEEP $CEEP is offline
i hope you are planning on stretching the wheelbase... a cj-5 on 40's at the stick length is gonna be tippy! I guess it all depends on what you are going to be using it for.
I'm just guessing here but somewhere in the area of a 2" spring should do it.
Old 11-07-2007, 12:45 PM
carwash's Avatar
carwash carwash is offline
do you mean dovetailed? a beavertail wold be flat and wide...
hahahah, no tech here, just being a dick!
Old 11-07-2007, 12:58 PM
thejoose's Avatar
thejoose thejoose is offline
most I have seen have stock wrangler springs SOA to run 40's. I think that stock cj springs would give a higher ride that stock wranglers. So you would need less cutting.
Old 11-07-2007, 08:59 PM
jhulsey's Avatar
Beaveratil.. Dovetail we all know what I am talking about. The rear will be stretched about 8 to 10" and the front about 4" and going full hydro. Right now I have a 2 " body lift on it. I will be clocking the dana 300 flat. So I might keep the 2" if necessary, otherwise I will clearance the floor . So do you think I could get away with 1" springs in SOA form?
Old 11-08-2007, 10:22 AM
$CEEP's Avatar
yeah definately 1" will be plenty if you keep the body lift. if you ditch the body lift 1" might be good as well.
Old 11-08-2007, 08:35 PM
jhulsey's Avatar
I talked with alcan again today. They gave me a better way to get exactly what i need. They said to mock up the height theway I want it to sit with 40's. Pull a string between the shackle an the hanger, then measure from string to spring pad. With that and the weights I have already given they will design spring rate to match.
Old 11-02-2017, 04:02 PM
jimmygarison's Avatar
Banned
Off course, if you keep the body lift it will be plenty, may be it is 1 lifted then excellent.
Old 11-02-2017, 08:20 PM
None of your plan makes sense. Mega lift(SOA) and clock the 300 flat on a short wheelbase do not go together. Not sure what you are making this to do? Body lifts became unpopular like 20yrs ago, they suck. I would say do a lot more research before you start destroying a classic Jeep.
Old 11-03-2017, 12:42 AM
10 year old thread brought up by our resident bot; jimmy
Old 11-03-2017, 01:09 AM
Ha, got me......don't I feel like an ass. Well only a little.
