Old 01-17-2018, 10:46 AM
Good progress last night. Finished shaving the badge holes. Which went pretty smooth and turned out good. They probably wont even need any filler.
Then it was time to tackle the lock hole. I needed to remove the step, but wanted it round and centered if possible. Puzzled it for a bit until I remembered I had this hole saw arbor that lets you expand existing holes. Luckily I had the perfect size saw for the existing hole (just had to go around it like 20x with a deburring tool for a slip fit).
Then carefully cut a circle of steel to fill the hole.
Skipping a bunch of steps, but basically i did a bunch of tacks a few times around to get it fully welded. Then ground, sanded, hammered, sanded, hammered, until we get to here. Its def not perfect and will certainly need some filler, but Im pretty pleased.
Up next is the third brake light. Im either going to shave it completely or shave it but add a thin flush mount LED. I cant find a good pic of what Id like to do, but basically youd just see the lens which would be a piece of lexan sanded flush to the contour of the lid.
Old 01-17-2018, 12:12 PM
Logging away the stacked hole saw trick!
Old 01-17-2018, 12:14 PM
This is what I have:
https://www.mcmaster.com/#hole-saw-e...uides/=1b61ggh
Old 01-17-2018, 12:53 PM
Thanks for the tip! I just added one to my next McMaster order.
Old 01-19-2018, 07:35 PM
Genius! I always machine a wood plug on the lathe to stick in the old hole then use a 1/4" transfer punch to center the hole saw.
That arbor looks allot simpler and waaayyyy faster.
Old 01-22-2018, 12:24 PM
Decided to go ahead and shave the third brake light. Still unsure what Im going to do to replace it but for now its gone. Im considering two to replace it; one inside at the top of the rear window for when the top is up, and one on the roll bar for when its down. (obv would have a way to disable either depending on the top position). It would be cleaner and more visible, which is good given the size of this car and the distraction level of drivers these days.
Anyway, I didnt get any pics of it welded up but here we have the filler done and the first coat of primer blocked down. I have a couple low spots and some pin holes to deal with. In general though I think its damn close. A quick coat of glaze here and there and another coat of primer and it should be set. I was surprised that there seemed to be some filler under the OE paint. Perhaps Karman did something with them?
Between filler drying I started working on a fender. Everything is so filthy still.
Shaving the marker lights in progress. The screw holes are already weld up here.
Unrelated to body work, the clutch hydro line and banjo fitting showed. Fit nicely.
Welded the -12 bungs to the HX and got two of the hoses done. Still waiting on some support spring for the lower, suction, hose.
Old 01-24-2018, 10:41 AM
Blocked the deck lid, added some glaze to address the pin holes and other spots, blocked, and re-primed. It should be good to go know with just a quick blocking.
Back to the fender. Welded and brazed the antenna hole up. Shoudnt need any filler.
Got the first coat of filler over the marker light area. Probably just a light coat of glaze will finish it off.
And then I started cleaning up the other fender when I noticed some filler squeezed thru a hole at the front corner, surrounded by a little rust. So I went to town and found this.
Yup, thats like 0.1" of filler and a hole from a dent puller stud, sigh. Not sure what Im gona do about this one yet.
Old 01-26-2018, 10:46 AM
Trunk lid blocked out with 400 dry. Pretty happy with how it turned out.
Stripped the drivers fender of its many layers of paint. Its super straight and zero rust. Ready to prime tomorrow.
Old 02-02-2018, 01:30 PM
Epoxy and 2k primed the fender last saturday. Turned out nice. I havent blocked it out yet, but it should be close, maybe just a little glaze around the area where I shaved the marker lights.
Then it was back to the trunk. The inside has just as much bad paint as the outside, along with a few dents. Spent forever stripping the inside and repairing the dents in prep for primers.
Sanded it out. Ready for the last coat of primer.
Just had to toss it on quick to see how it looks. Diggin it.
I was tired of sanding so last night I decided to focus on the hood latch. My oe one was a rusty mess so I sourced a German aftermarket one from Poland.
Years back I modded the oe one to release through the grille like the early rabbits. The job I did on it sucked so I fixed that up last night and mated it to the new latch.
Its basically just a tab welded to the release where normally the cable would hook to. I cut off anything associated with the cable and drilled a new hole for the spring.
Also added nutserts for mounting the base to the core support.
Naturally the safety catch hook hit the heat exchanger, which I knew would be close. Luckily it was just low enough a small clearance through the top plate gave it enough room. I also trimmed the catch a tiny bit for added clearance (not shown in the second pic)
Then I pulled it all apart so it will be ready for nickel plating.
Old 02-05-2018, 04:35 PM
Primed the inside of the trunk. Its now ready for seam sealer.
Pass fender stripped. Didnt find any other surprises so I decided to fix the previously hacked repair on the front corner.
With the rest of the 1/8" of mud ground off it was a huge mess. The backside was quite rusty as well. Stupid dent pullers. You can see some leftovers of the one stud, top left of the damaged area. The top of the fender behind the damage was also pushed up quite a bit so I hammered that flat using a poster board template of the drivers fender.
Cut out the old repair
Hammered a replacement piece to shape.
Welded it in place and sanded it out.
Last night I shaved the marker light holes and got it glassed in. Its not a great shot of it, but you can see just how little filler the front repair I made needed. A little better than the original repair.
Old 02-07-2018, 10:37 AM
Took a break from sanding and started on the catch can.
Naturally I couldnt just make a square box. I wanted the one corner to be rounded.
Bent up some 0.090" to a 1.5" radius on our little Baleigh brake at work.
Then cut and fit all the other pieces and got most of it tacked up. Im still waiting on the top panel that a guy I work with is cutting on his cnc for me. Should have that tomorrow.
Ill try to explain how this is going to work. The large oem vent in the block is going to attach to a tube in the chamber with the rounded corner. The air will travel up over the first wall, under the second, over the third, and then there will be an opening in the bottom of the front most chamber. The whole thing will be filled with ss wool to capture the vapors. The bottom is angled to funnel the captured oil where there will be a drain. Its hard to see but the first interior wall is flat at the bottom allowing oil to go under it but most of the air to be directed over it. The third interior wall follows the contour of the bottom panel so I can seal it to hold the oil within the first three chambers. Phew. It should make more sense as it comes together.
Old 02-09-2018, 10:29 AM
Realized wed am that I welded the damn mounting flange of the tank on upside down. UGH. Last night I cut all the tacks off, cleaned up the panels and flipped it over the right way. Took about an hour, so not SO bad.
Then added a bung for the drain and the inlet tube and welded it all up.
Welded a piece of rectangle tube to the side of the HX to attach the tank to. The tab out the side should make sense now.
Up next was the drain. The drain will double as a secondary mount for the tank, I still need to weld on a mounting tab that will bolt to the frame rail. That groove in the frame rail was meant to be there I guess. It took me a while to get the bends right for the drain. I also had to trim the tube sleeves so Id have enough room for the flare tool dies but I think it worked out pretty slick.
The inlet tube is 1.25" to match the oe breather on the block, and is angled to go under the upper radiator hose. Ill connect the two with a 1.25" silicone 90.
Drain will get a male plug.
I now have the top plate back from my CNC buddy so I should be able to get that welded on this afternoon.
Old 02-09-2018, 12:59 PM
All this time I was under the impression you were a super. With all the crazy awesome stuff you're doing, I figured for sure you couldn't be human! But apparently even supers make mistakes.
That turned out great! Are going to do both "clean side" and a "dirty side" catch cans or just "dirty side"? I like how you did a hardline for the drain. I see so many of these with a barb right at the tank and no means of getting the contents somewhere easy to drain to or just a length of rubber tubing. Instead of a cap, you might consider a small ball or petcock valve for convenience.
Old 02-09-2018, 01:26 PM
Thanks!
I wasnt going to discuss "the mistake" but I thought it might be good to share that we all F up sometimes. I blame welding at 12:30am . haha
Just doing a dirty side catch can. This is simply going to vent to atmosphere, there will be no vacuum anywhere on it.
I did my catch can on the cavy the same way, makes it so much easier to just crack open and drain. A valve might happen, we'll see.
Old 02-12-2018, 12:30 PM
Catch can lid welded on (note groove for sealing o-ring), output slot cut in the bottom, and a mounting tab for the drain line welded on.
I also tweaked the drain line spacing to the frame rail for all you that were super concerned.
Will drill the frame once the motor is out next time.
Next I need to decide if/how Im going to fit a breather line or two to the valve cover.
Old 02-14-2018, 11:40 AM
Silicone 90 for the crank case vent trimmed and in place. Itll sit straighter once clamped (not that youll ever see it again).
Ive been hating the fuel press regulator cup on the end of the fuel rail for a while now. The original plan was it would be simple, "cheap", and require less fittings. But now it just annoys me and I feel that Id prefer to have some control over fuel pressure if needed.
So last night I hacked the cup off and welded a -6 fitting on. Its so much cleaner. Im going to mount the small Fuel Lab FPR under the fram rail. Sure it wont be the easiest to access but it should be a set it and forget it deal.
Before
After
Old 02-20-2018, 11:13 AM
Big update:
Finished up the catch can. I decided to add one breather to the valve cover. Not so much for the vent but that I needed a place to fill oil since I shaved the oe fill cap. haha
Fitting welded and smoothed.
To keep the hose as long as possible to compensate for engine movement I welded a piece of tube to the catch can the hose slips over, vs a bung and fitting. Also did a little bump in the hose. I did use silicone hose I had lying around which is not lined correctly so Ill need to either source some lined hose or just use standard pushloc hose when it comes to the final install.
Finished up the hood latch mods. Originally the pivot for the safety catch was staked in. I needed to remove it in order to be able to nickel plate everything so a new pivot was required. I sourced a internally threaded shoulder "bolt", drilled it out from 8-32 to 1/4-20 and turned the knurling / labeling off. Not shown: drilled out the hole in the safety catch to fit the shoulder bolt and welded extra material to the edge to compensate for the larger hole.
Original pivot ground off
Shoulder bolt before
Everything modded and assembled complete with ss ARP 12 point bolt.
Next was to finish up the revamped fuel system. The Fuel Lab FPR fit nicely under the frame rail. I just needed to make a little adapter plate to mount it to and redo the lines quick. Ill rivet this in after the chassis is painted hence the temporary clecos
And last but not least FINALLY got the header and down pipe fully welded.
First time welding a header like this. It was a total pain trying to do it all in one piece, but I thought I could without separating the runners and I wanted to try and minimize warping by keeping it on the jig.
Thankfully the Monster 14 cup didnt disappoint and I was able to have huge tungsten stickout while maintaining a clean weld.
All welded up. It probably took me a good 5 hours of welding 3/4" , re-position manifold, weld antoher 3/4", repeat infinity times. Its not the best job ever but itll certainly pass.
It did pull a tiny bit on the jig but nothing to worry about. The head flange was also pretty flat. Nothing I cant sand out quick on my big belt sander.
Then it was the down pipe's turn. Had to make a jig to weld the turbo v-band flange. Both to hold it flat and to be able to purge it properly. I was quite pleased with this weld.
For the saddle O2 bung the fit wasnt quite right so I welded the sides and then used a hammer and punch to adjust the edges for a tight fit.
All done.
Still fits!
And with that i THINK im done with the motor / turbo fabrication. Tonight Im going to do a once over everything an then it should be time to remove the motor and get cranking on the body!
Old 02-20-2018, 11:59 AM
Beatiful! That is metal art at it's finest.
Old 02-20-2018, 01:34 PM
Thank you sir!
Old 02-20-2018, 04:35 PM
Curiosity.
How much power will this jewel be making?
