Old 04-20-2008, 02:25 PM
Zim's Avatar
Zim Zim is offline
Which software for my needs?
I'm wanting to build a tube frame vehicle and anything else I can think of. Gocart frames, tools, bumpers, stuff like that will be what I use it for. I'm assuming since I wanted to build a tube frame 3-D is a must?
Old 04-20-2008, 02:57 PM
Rock4XFab's Avatar
3D is a minimum if you want to jump in head first with those types of projects.. You will not regret it.
http://rock4xfabrication.com
1-847-672-9653
1-847-544-1823
Old 04-20-2008, 02:58 PM
3D is a must and PRO would be recommended when you are putting multiple tubes together.
Old 04-20-2008, 06:38 PM
If you just get PRO to begin with (since it has the assembly feature) I can assure you you won't be disappointed....in fact you'll be simply amazed at all the program can do for you
Old 04-20-2008, 06:40 PM
Ladderbar's Avatar
I am very computer illiterate and I have Pro and use it almost to it's fullest. It's easy to use and understand and will do what you want and more. My $.02
Old 04-20-2008, 06:42 PM
Zim's Avatar
Zim Zim is offline
What are the added features to the SE program over the pro?
Old 04-20-2008, 10:12 PM
Check here >> http://www.2020softwaresolutions.com...ison_chart.htm
Old 04-20-2008, 10:45 PM
Zim's Avatar
Zim Zim is offline
Thanks for everyone's replies. Now I just need to save up some greenback.
Old 04-20-2008, 10:52 PM
Mopars 4 Life's Avatar
This is one good reason why Fabcam offers the upgrades...you can start out low and get the "feel" of the software...like with the EZ,then upgrade to 3D,then PRO,and so forth. I purchased the 3D and less than a month later I upgraded to the PRO. PRO is good though as the assembly feature makes working on your design really easy...
Later,Brian
Old 10-04-2017, 05:09 PM
jimmygarison's Avatar
Banned
I think it is one the best forum, I purchased the 3D and less than a month later I upgraded to the PRO. PRO is good though as the assembly feature makes working on your full time it very easy.
Old 10-04-2017, 06:18 PM
If JimmyG is using PRO then you should really consider it :).
HTML code is On
